Has anyone installed these........
if so, did you have to modify them to fit??
seems like mine just won't seat without some modifactions.
If those are door seals the holes should line up. I have some clear ones. If I remember right I had one side that did not line up. I just drilled through the hole into the sill. It installed without a problem.
Yea, I am having a real problem around the emergency brake lever. Seems like these sill covers are too tall. Looks like I will have to trim some of to get to seat right.
Mine didn't quite fit right around the E-brake either, but with a little persuasion the sill piece would slide in between the E-brake trim and the carpet.
I have those installed in my 92 and they fit well, I just had to drill a hole on the outside part so I could screw them...
I have a black interior, it looks great with those
I put em on my 87 a few years ago. I've scrapped the drivers side so much getting in and out that most of the white letterng is gone. They fit perfect without any problem.
