Re-Sealing Targa Top, Which Adhesive?
I'm personally refurbishing my own clear targa top on my 86. The glass and base are in good condition. i have cleaned off the old adhesive and am ready to re-apply the adhesive.
What type of adhesive do I use? I checked and the sealant the factory uses is only available to the factory. Will general 3M winshield adhesive work? Has anyone done this?
I would have a professional do this, but neither a Corvette shop, nor the auto glass places I called in the Atlanta area seem to have done this or know how. And I don't want to spend the $$ on a refurb top when mine is so close to fine.
Originally Posted by Flyingboy
Melrose people? How do i contact them?
Melrose T-Tops
Weld-On #40
http://www.eplastics.com/Plastic/Lex...VE-IPS-40-PINT
It's a 2 part epoxy, something I've heard from others on the forum that is used by the factory. There's another thread where one member uses 3M Windshield Adhesive but it doesn't work. I haven't tried the Weld-On yet but the rep I spoke with said this is what you have to use when attaching acrylic tops. If anyone want a follow up, PM me or give me a holler and I'll give an update!
I know this is an old thread but I've been trying to find out what type of sealant is used to attach the acrylic top to the frame without any luck on the forums or any other sites.
Weld-On #40 It's a 2 part epoxy, something I've heard from others on the forum that is used by the factory. I haven't tried the Weld-On yet but the rep I spoke with said this is what you have to use when attaching acrylic tops.
The aluminum frame and the acrylic top have different thermal rates of expansion, so any adhesive you use needs to have enough flexibility, or the adhesive will crack! Most epoxys don't have this flexibility. I did the top on my '84 several years ago, using Dow Betaseal, which is used for replacing glued-in windshields. Search on Betaseal for my complete procedure.
I'm wondering if DOW Betaseal is a high modulus seal (flexibility). The key is to find something that will flex, like you said since we're dealing with two different materials. Can't argue with your results thought! Still holding up?
The place I spoke with is Ridout Plastics. They're the company the dealer outsources the tops to. That's the reason why I'm hesitant to choose between Weld-On 40 and Betaseal although I do appreciate your tips. Just don't want to do it twice if I don't have to!
Here's a quote on the Weld-on 40 from the Ridout Plastics website:
"BONDING RECOMMENDATIONS
WELD-ON 40 is recommended for bonding of acrylic plastics especially where good clarity retention is required. It is versatile having many applications in the sign industry and in the manufacturing and repair of aquariums, museum quality cases and other plastics fabrication industries."
As you can see, this is for bonding plastics with similar characteristics, not aluminum! Tight joints are required, and there is no resiliance! Translation: failure guaranteed!
Yes, my top is doing fine! It was 100 degrees here last week, and my car gets plenty of sunshine here in SoCal.
After that, gotta figure out what's up with my tranny then the car will be running strong!
