What's the best way to smoke the tires
Old 08-03-2001, 03:58 PM
chuck94vet
chuck94vet's Avatar
Default What's the best way to smoke the tires
What's the best way to do a burn- out with an A/T?:blueangel:
Old 08-03-2001, 04:11 PM
Raysur
Raysur's Avatar
Default Re: What's the best way to smoke the tires (chuck94vet)
Hit the brakes slightly and floor the gas. This locks up the front tires and lets the rears break loose.
Old 08-03-2001, 04:17 PM
90 Corvette ZR-1
90 Corvette ZR-1's Avatar
down shift to 1st, apply breaks slightly, nail gas, watch tach, when it gets close to red line shift to second.
PS turn ASR off first
Old 08-03-2001, 04:37 PM
Mikez40
Mikez40's Avatar
Pour brake fluid on them, and floor it :eek:
side note: don't get the brake fluid on your paint :D
Old 08-03-2001, 05:18 PM
Gozar
Gozar's Avatar
Cruise-In IV Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: What's the best way to smoke the tires (Mikez40)
With my 3:08 gears all I have to do is turn off ASR and floor it. On most surfaces they just lite up. On really sticky surfaces or super-hot asphault I have to power-brake it a bit.
Old 08-03-2001, 05:41 PM
Fastguy
Fastguy's Avatar
St. Jude Donor '03-'05
What's the best way to smoke the tires?
Hmmmm, I usually cut them up in small pieces, pack them in the bong and take a few hits. Some people like to use papers but I find the taste nasty. A small power hitter is good for travel but the hit is WAY too hot, so I would definitely go with a medium to large bong. What was the question again? :crazy: :crazy: :crazy:
Seriously, the above mentioned stuff works but you are really heating the tranny up and the back brakes. If you drag race a lot, a line lock is a wise investment. You pump the pedal, hit the switch and let off the pedal. It keeps the pressure applied to the fronts and you can then easily burnout. Its fun at parties too. :yesnod:
Old 08-03-2001, 06:16 PM
TA
TA's Avatar
Default Re: What's the best way to smoke the tires (Fastguy)
I'm not sure if its due to my balding skaterbacks, or the earth shattering torque my car lays down :rolleyes: :rolleyes: Seriously though all I have to do is stomp on the gas I can pretty much melt the rear tires even w/ my 2.59s.
Old 08-03-2001, 10:29 PM
INTIMIDATOR ZO6
INTIMIDATOR ZO6's Avatar
Just lightly hit the gas pedal :D Works for me
Old 08-03-2001, 10:39 PM
Ezgoin721
Ezgoin721's Avatar
1. Build a 383 SuperRamed Stroker. 2. Get in the car and start the engine. 3. Put the car ing gear. 4. Plant your right foot firmly on the carpet. 5. Hold on to your A$$. 6. Purchase new tires! :yesnod:
Old 08-04-2001, 01:34 AM
Mr Mojo
Elite Torch Red Member
Support Corvetteforum!
Mr Mojo's Avatar
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Put a line loc in and do this: click here
Old 08-04-2001, 02:32 AM
snydcat
snydcat's Avatar
I just mash the gas pedal to the floor :chevy
Old 08-04-2001, 02:50 AM
corvette dude
corvette dude's Avatar
First you break it up and remove all the seeds,
then you roll it up in a paper of your choice,
oh tires nevermind...
Old 08-04-2001, 02:55 AM
Bat Man
Bat Man's Avatar
Default Re: What's the best way to smoke the tires (corvette dude)
Shoot I couldn't smoke my tires if my life depended on it, I hope its not the car. I'm thinking its the tires. Supposedly they are really good tires.
Old 08-04-2001, 04:50 AM
NoWorries
NoWorries's Avatar
Default Re: What's the best way to smoke the tires (Old Sport)
Brake, Gas, Go
If your car won't spin the tires, something is wrong.
My stock L98 w/ 2.59s broke the tires free on the test drive...and even when my fuel pump died at Firebird I was able to spin the tires without going through the water box...it died directly there-after.
Old 08-04-2001, 05:32 AM
Wallace
Wallace's Avatar
I think MOJO b the man! :eek:
Old 08-04-2001, 08:17 AM
Mr Mojo
Mr Mojo's Avatar
You got the same tires as me
Old 08-04-2001, 12:30 PM
MTVette
MTVette's Avatar
Default Re: What's the best way to smoke the tires (TA)
Like TA said. All I have to do with mt 92 LT1 is turn off the ASR and mash the gas pedal. Since my tires are fairly new and I don't make a million bucks a year, I don't let 'em burn too long - I light 'em up for a second or two and then back off on the gas to GO!. Never have yet just let 'em burn until they grab - makes too much noise and smoke. :D
To What's the best way to smoke the tires
Old 08-04-2001, 03:13 PM
Lloyd Smale
Lloyd Smale's Avatar
try a bong! :cheers: :jester
Old 08-04-2001, 11:03 PM
Crushinator
Crushinator's Avatar
Mr. Mojo could write a book on this subject. Only wish I could see one of his burnouts in person. Love that smell!
All you should have to do is apply the break and stomp the gas. They should light right up.
Old 08-05-2001, 01:39 AM
BobMachus
BobMachus's Avatar
I can't even get mine to chirp on straight line accleration. I mash the gas and the car just accelerates, at about 2000 rpm it accelerates hard (like a turbo coming on, or a light NOS hit). This is driving me nuts!
Bob
Quick Reply: What's the best way to smoke the tires
