Spun Out
Old Feb 14, 2006 | 11:05 AM
Demonic85's Avatar
Demonic85
Default Spun Out
I was on my way to school today and when I was going around a turn (not a corner) I went sideways. I was only going about 20mph, light on the throttle, and ive taken that turn much faster before and never had problems. I dont understand what happened, my tires are relatively new and I just raised the air pressure to 40 psi last night because they were low. The same thing happened to me a few months back in my 2WD truck on the very same turn.
Old Feb 14, 2006 | 11:31 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
40psi.. should be 30 to 32 psi...
Old Feb 14, 2006 | 11:37 AM
Demonic85's Avatar
Demonic85
oh really? the tire says max is 44 psi. I have 16/55/255 on my '85
Old Feb 14, 2006 | 11:38 AM
Red Dragon 79's Avatar
Red Dragon 79
35 psi is the max i will go. soft surfaces with really full tires = traction. hard surfaces with less air = traction
Old Feb 14, 2006 | 11:42 AM
4REGT4's Avatar
4REGT4
40psi is WAY too much. I agree that 30-32psi is where you should be. If your tires are wearing out in the center you are over filling them (even 35psi is over filling that tire).
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
Look at the sticker on the drivers door..I run 30-32 front and 28-30 rear cold...
Old Feb 14, 2006 | 12:18 PM
Demonic85's Avatar
Demonic85
I was just looking at the tires. They were at 25 psi which seemed really low to me. I'll lower them to about 32-35 psi and see if thats any better.
Old Feb 14, 2006 | 12:21 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
The max pressure on the sidewall is for load-carrying purposes. Running a tire at max...or even higher-than-normal pressures...will reduce the traction.
40psi will reduce traction a noticeable amount, but not to the extent that you will spin on normal turns at low speeds at small throttle openings.
Something else was going on (fluids on the street/tires, wet leaves on the road, sand, etc.) that the high pressures exacerbated.
Your Corvette should have a placard on the door that says 30psi is the recommended pressure for normal driving. Vary from that at your own risk.
I normally run 30psi. If I go up to even 35...I can definitely feel the difference.
Larry
code5coupe
Old Feb 14, 2006 | 12:25 PM
Demonic85's Avatar
Demonic85
i'm gonna end up getting myself killed by putting too much air in the tires, i'm letting some air out as we speak. Thanks guys
Old Feb 14, 2006 | 02:30 PM
SJW's Avatar
SJW
Definitely, as others have noted, inflate according to the decal on the driver's door.
The pressure rating on the tire's sidewall is only the tire manufacturer's upper safe limit on inflation, it is NOT the recommended inflation (which the manufacturer cannot provide, as they do not know what vehicle the tires will be used on, etc).
Also bear in mind that if the weather is very cold, your tires will not grip like they will in warm weather, because the tread compound will tend to harden in lower temps. Make allowances for this, or you may wind up in trouble.
Be well,
SJW
Old Feb 14, 2006 | 03:17 PM
WEH 2000C5's Avatar
WEH 2000C5
Same turn , 2 different vehicles ,same results . My guess something contaminating the road surface .On a curve some truck has barrels of fluid sloshing out onto the road surface. Could be a route this truck travels frequently.
Old Feb 14, 2006 | 04:19 PM
Muffin's Avatar
Muffin
What SJW said.
Old Feb 14, 2006 | 04:35 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
Yeah, there are a couple of turns that I travel quite frequently that I have to watch in both my Vette and truck. The road is just worn down and the pebble/rock under layer is very, very slick. I have a rough time getting traction in the dry weather, much less when it's wet.
Old Feb 14, 2006 | 04:44 PM
Bigredwing's Avatar
Bigredwing
I have a ritual of checking the air pressures on all my vehicles every Saturday morning. Must be a carry over from my military days when I had to shine my shoes regularly. It always makes me feel like I accomplished something for the day!
If you have slid on the same corner maybe a trash or fuel truck makes takes the same route and spills something on the road?
Old Feb 14, 2006 | 06:44 PM
kopbet89c4's Avatar
kopbet89c4
That is a tire with lots of sidewall!! Do your tires serve as an emergency floatation device?? Or did you mean a 255/50/16 tire??
J/K...
I bet they do help you out quite a bit when you are parallel parking and there's a 4" curb to your side.
Old Feb 14, 2006 | 06:47 PM
C4driver99's Avatar
C4driver99
Like said above over filling your tires cause premature wear and less traction.
Old Feb 14, 2006 | 11:34 PM
SJW's Avatar
SJW
And a ride that'll beat the living hell outta both you and your car...
Be well,
SJW
To Spun Out
Old Feb 17, 2006 | 08:41 AM
bluealtered's Avatar
bluealtered
As you run the car your tires will heat up,(it depends on how cold/ warm outside) and may gain a couple of pounds, in the summer,running through the mountains at speed i can gain between 2-4 pounds depending on how hard i scrubbed them in the corners, i start at 30psi. ...
Old Feb 17, 2006 | 09:37 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
40 psi is too much for sure. Always go by the sticker on the door(unless it's a Ford Explorer, that sticker is just plain incorrect).
On my 95 they recommend 35 psi for speeds over 150 mph.
For highway driving and road trips, I'll keep 35 psi, but for around town driving and some fun, I'll go down to 32.
For racing, on my six speed car with street tires, I'll have 44 in the front and 28 in the rear.
My automatic will take 45 up front and 22 in the rear.
Note that the psi will go up as the tire heats up and also note that running too low will cause excessive heat and can lead to failure.
The engineers of our cars have done extensive testing so it's best to follow their recommendations.
Old Feb 17, 2006 | 10:59 AM
cv67's Avatar
cv67
St. Jude Donor '05
Im wondering if most of the problems associated with the tire blowouts on the Ford Exploders werent due to underinflation. I bet most of the people that drive those never check the tires. Like you said, pressure gets low the tire gets hot and fails in a hurry.
