question about lights on dash
Old May 4, 2006 | 11:22 PM
rightofway's Avatar
rightofway
Default question about lights on dash
when are all of the lights on the dash to the right of the display switches supposed to come on and what lights are there
TIA
Old May 4, 2006 | 11:26 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I've only seen...
Check engine
4+3 overdrive
Brake warning light
and I expect it varies by year too.
Old May 5, 2006 | 12:22 AM
Z51L83's Avatar
Z51L83
om my 84 it goes
door ajar
hatch ajar
brake
check eng
and i've seen a couple other when the light hits just right
overdrive
choke
can someone explain why they put a choke light on a fuel injected car?
Old May 5, 2006 | 12:38 AM
CentralCoaster
Is there a seatbelt light too?
Old May 5, 2006 | 12:39 AM
Demonic85's Avatar
Demonic85
lol, idk cause yours is that weird crossfire injection. The injectors are in the throttle body arent they? Maybe that has something to do with it. My '85 doesnt have a choke light.
Old May 5, 2006 | 01:10 AM
Z51L83's Avatar
Z51L83
yeah i forgot about the light that wont go out
Old May 5, 2006 | 03:52 AM
86PACER's Avatar
86PACER
Originally Posted by Z51L83
om my 84 it goes
door ajar
hatch ajar
brake
check eng
overdrive
choke
In 86 there is also Security, Fasten Seatbelt, Low Coolant, and ABS.
I always wondered about the choke one myself.
Old May 5, 2006 | 09:57 AM
thebeerman's Avatar
thebeerman
I believe that all lights should come on for a visual check when you turn the key on and before you hit the starter, for a bulb and sensor check, then all that test positive should go out.
Old May 5, 2006 | 12:43 PM
rightofway's Avatar
rightofway
so theres supposed to be
door ajar (never seen it on?)
hatch ajar (need to check for it)
security never seen it when does it come on?
low coolant (never came on even when there was zero coolant)
Old May 5, 2006 | 01:55 PM
86PACER's Avatar
86PACER
For '86
Door ajar. On when either door is open. Your door ajar buttons on either door may be stuck pushed in.
Security light should come on each time you open the door. It should flash and then turn solid when you hit the door locks from the inside with the door open.
Low coolant. This light will never come on even with a good bulb if the Low Coolant module located under the passanger hush panel below the ECM is not plugged in.
Hatch Ajar. Mine has never come on.
Old May 6, 2006 | 02:18 AM
Z51L83's Avatar
Z51L83
i also forgot about the tweaking security light
Old May 6, 2006 | 01:35 PM
rightofway's Avatar
rightofway
will the security light not come on if the door lock switches are removed
Old May 6, 2006 | 09:25 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/agent86/TellTale.pdf
Old May 6, 2006 | 09:54 PM
vader86's Avatar
vader86
whats the right bulb # for the DIC?
Old May 6, 2006 | 10:17 PM
86PACER's Avatar
86PACER
This is the bulb specs for the entire car.
To question about lights on dash
