Breaking nightmare
Old Jul 3, 2006 | 11:52 AM
volume351's Avatar
volume351
Default Breaking nightmare
Ever sice i bought my corvette the breaks have never been that good.
My truck can stop faster, so i started looking at things and figured it was my break booster. (didnt hold any vacume) Well i replaced that.
and after bleeding the breaks...starting at the abs in the back then rr..lr..and so on..i finished up and drove around the block. Breaking did improve but it doesnt seem like its right...i still can stop faster in my truck as it seems...
whats another thing i should look at??
whats the right way to bleed the breaks??
should i just take it to the dealer?
thanks
Old Jul 3, 2006 | 12:04 PM
rick lambert's Avatar
rick lambert
I always hate bleeding brakes, but you start in the back with passenger side, then back drivers side, front passenger side then drivers side..need two people, just gotta make sure you get all the air out.
Old Jul 3, 2006 | 12:06 PM
volume351's Avatar
volume351
well thats the way i did it. but i started with the abs..then the rr..lr..rf..lf..
Old Jul 3, 2006 | 12:51 PM
Demonic85's Avatar
Demonic85
Does your truck also have ABS?
Old Jul 3, 2006 | 02:59 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Rotors, pads not glazed? Lines not bulging, holding pressure? All calipers working, stops in straight line, too? Fluid's new (you must've put in new fluid)? What pads, if you can tell/recall--could they be racing pads--which need lots of heat? Does it work better after several stops? Tire pressures ok? How's the master?
Old Jul 3, 2006 | 04:15 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Though i'd read that it was the RR, RF, LR, LF...
Old Jul 3, 2006 | 04:20 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Depends. For '96 you are right (RR, LR, etc.). Maybe diff for diff years????
Old Jul 3, 2006 | 07:10 PM
robertt43's Avatar
robertt43
Default brakes
I replaced everything on my 84,hoses,calipers,shoes,booster,m/cylind.,rotors,and they are still "bad". Really have to lean on the pedal to make it stop;and sometimes it will creep in traffic if I'm not careful. Don't know what else to do. I sometimes wonder if the metal booster is working,[had plastic before and the old brakes were better than these,and I wonder if the crossfire intake makes enough boost] I think I have to find somewhere to check these out.Any ideas?
Old Jul 3, 2006 | 10:06 PM
volume351's Avatar
volume351
there is a guy that works at the chevy dealer that lives behind me..i think ill ask him to take it in and see what they come up with...or some break shop...
my abs and asr lights come on the second or third time i break...
Old Jul 3, 2006 | 10:32 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
That's not right. ck the FSM; see what it says about that, if it does.
Old Jul 4, 2006 | 04:46 AM
volume351's Avatar
volume351
um...sorry but i have no idea what the fsm is...
Old Jul 4, 2006 | 06:34 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
It really doesn't matter at all.
FSM = Helm (Factory GM Service Manual)
If your booster pushrod is not adjusted out correctly, you won't get as much booster assist.
Old Jul 4, 2006 | 09:36 AM
mikeb's Avatar
mikeb
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
Usually a sign of air in the system.
Old Jul 4, 2006 | 10:11 AM
JrsTurn's Avatar
JrsTurn
master cylinder bleeding by
rr,lr,rf,lf All air must be removed
Not yet...Does the pedal feel spongy? Does it give when you hold it depressed? Do you have a firm pedal?
Someone else mentioned glazing on your pads, that's a good call as well.
Good Luck, Larry
Old Jul 4, 2006 | 03:12 PM
volume351's Avatar
volume351
no the pedal is ferm it just doesnt have power...i will bleed them again...
does anyone know if your need to bleed the abs thing a ma jig in the rear compartment?
Old Jul 4, 2006 | 03:14 PM
CentralCoaster
I replaced a bad booster once, and the replacement was also bad. I returned that, got another, which was also bad.
Don't assume the new or reman parts are good.
Old Jul 5, 2006 | 01:19 AM
volume351's Avatar
volume351
yea my first one was bad...then my second one was bad...now this ones good...im going to bleed the breaks again..
To Breaking nightmare
Old Jul 6, 2006 | 12:58 AM
JrsTurn's Avatar
JrsTurn
Update?
Old Jul 6, 2006 | 01:30 AM
quantum-theory's Avatar
quantum-theory
We're all here to teach and to learn. In that spirit -
break - what happens when you drop something.
brake - what happens when you push the pedal next to the long skinny one.
Please do not take offense, but accept in the manner given.
Old Jul 6, 2006 | 02:32 AM
CentralCoaster
(And once again, the order you bleed them does not matter.)
And don't forget to adjust the play out of the booster pushrod.
