Rear hatch won't open
I have an intermittant probelm with the rear hatch release. when the release button is pressed on both the door or the one located under the center console, i can hear a very faint click, and the hatch never releases. It doesn't happen all the time, only happens when it i need to open it most. I was thinking maybe the rear hatch relay switch. Any more thoughts?
The rear hatch also has a solenoid. I had problems with mine, ordered a new solenoid, installed it and created a new problem. Pay close attention to the way you take the old solenoid off. You must install the new one in exactly the same way. It is possible to get the new solenoid on backward without knowing it! At least that is what I did! Couldn't get the hatch to open at all! Had to take it to the dealer to get my mistake corrected! Was told that I had installed the new solenoid backward!
The new solenoid improved my situation but did not completely correct it. My switch on the door works occasionally, but not always. My switch under the console works all the time. I even replaced the door switch and still did not fully correct my problem.
There is a release cable for the rear hatch, but it can be difficult to find without scarring your knuckles trying to locate it within the plastic trim area!
CF JASOC Member
If you reach under the shade in the back, just to the left of the handle (as you look at it from inside) in the middle of the shade, you'll feel a small metal cablle that you'll likely have to grab with pliers. Pull it and the hatch will pop.
St. Jude Donor '08-'09
Mine is intermittant too.
I actually added a wire crimp or fishing shot weight to the end of the little pull cable so I can grab it easier. I have to pull the cable 9 times out of 10.
I checked corvette america and downloaded a diagram...looks like the solenoid is actually attached to the cable. they sell the the cable and the solenoid for about 95.00 bucks, since i already ordered the relay, i'll probably go ahead and replace both.
Thanks.
Thanks.
CF JASOC Member
Thanks.
Thanks.
As I recall, you first remove the targa latch handle, then the interior pieces, then the big metal bracket that keeps you from getting to the latch/solenoid (you have to remove 4 nuts, and 2 of them are under the edge of the carpet). You'll see the relay to your right all wrapped up with tape to the wiring harness. After that you can remove the one bolt that holds the solenoid to the latch and lift it off after you disconnect the wiring harness. It is soooo cool to have a hatch that works every time again.
Good Luck.
