Clutch Fluid, what type ?
Other then the GM clutch fluid, what are the better clutch fluids that I buy at auto parts stores ?
I have a 92 6 speed.
thanks.
thanks.
Valvoline Synpower DOT3 and DOT4 brake fluid.
It is a borated ester than has higher boling point and absorbs less water.
I have used it for the past 2 years in my Verts
Location: One day you're a Comet...the next day you're dust... Arkansas
St. Jude Donor '08-'09
Just remember. its just an old Chebby... so unless you are one of those people that thinks synthetic solutions is the answer to everything, then cheap stuff will do in most cases.
I use the Synpower and have had ZERO problems. I highly recommend it.
GM recommends a specific fluid for the clutch hydraulics so they won't squeek... The Synpower has never allowed the clutch hydraulics to squeek.
