Old Feb 19, 2015, 07:02 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
Print Wikipost
C4 Window Regulator replacement
Old Sep 10, 2006 | 05:06 AM
alyle5864's Avatar
alyle5864
Banned Scam/Spammer
Default C4 Window Regulator replacement
Anyone got a procedure for replacing the window regulators ina C4? Got a replacement coming and don't want to screw up. Is it difficult?
Old Sep 10, 2006 | 10:29 AM
Jet-Jock's Avatar
Jet-Jock
Is this an upgrade to the newer style? If so, do a search here there was a post with instructions a few weeks ago posted.
Old Sep 10, 2006 | 10:53 AM
BigTexas's Avatar
BigTexas
I didn't know there was a newer style! Tell me more.
Old Sep 10, 2006 | 10:57 AM
Jet-Jock's Avatar
Jet-Jock
http://forums.corvetteforum.com/show...ndow+regulator
Old Sep 10, 2006 | 02:40 PM
BigTexas's Avatar
BigTexas
LOL! I have a 95. I guess there is no newer version. I am going to have to buy a new window regulator for the drivers side. My window rolls up and down fine but the regulator is not holding the glass in very well anymore. I guess I am going to call Chris at superior chevy.
Thanks anyway.
Old Sep 10, 2006 | 02:45 PM
Jet-Jock's Avatar
Jet-Jock
Thanks anyway.
Your problem is more likely broken window guide stops. When you call him order the left and right one's. To replace you'll have to remove the door panel and inner accessory panel (aluminum) then it requires a special tool to hold the outer side flat nut but some have been successful with needle nose vice grips.
Lesson for C4 owners don't slam the door with the window partially open or use the window to shut the door. Once you see how it is held in place and guides along a rod, you'll under stand why. Apply force will break that plastic guide.
Old Sep 11, 2006 | 12:34 AM
alyle5864's Avatar
alyle5864
Banned Scam/Spammer
I looked at my doors and the drivers door appears to have the newer regulator, there are two bolts on the bottom. I think the previous owner told me he replaced it. On the passenger door there is only one bold about in the middle of the door. Looks like the passenger regulator is the old style. The one I have coming is the newer style.
Thanks for the links, this should help.
To C4 Window Regulator replacement
