Plugs Were Easy with the right Tool
I changed out the plugs last Saturday for the first time on my 95 LT1. I collected as much info and tools as possible before I started. After reading all the threads you guys almost had me scared. Four hours? Maybe without the right tools. I had all 8 plugs out in less than 30 minutes. No bloody knucles either. I think it was mostly due to this tool I picked up off ebay. I used that one with a few other socket sizes that I bought locally. I'll have to measure all the sizes I had. The socket was bored out and fit all the way on the plug to break it loose. Then I would use a socket a bit longer to finish removing. I spent more time dropping plugs in the engine and greasing them with anti-sieze than anything. Yes, I tried using rubber hose to get them started. I think next time I'll use an old plug boot. The only thing I removed was the three ASR bolts to get it out of the way. I also bought the sidewinder tool for this job. I tried it on one plug and threw it aside. It is too bulky and difficult to turn to really be usefull. I think some have had luck with it on the older C4's. It was a waste of money for me. This job really was a whole lot easier then I thought it would be. Anyways I just wanted to share how usefull the right tool can be. A lot of people have rigged up similar tools or purchased the wrench seperate. Next time I'm pretty sure I can do it in under an hour. By the way I do have headers but from what I've read it doesn't make much of a difference.
http://cgi.ebay.com/ebaymotors/CORVE...spagenameZWDVW
I changed out the plugs last Saturday for the first time. I collected as much info and tools as possible before I started. After reading all the threads you guys almost had me scared. Four hours? Maybe without the right tools. I had all 8 plugs out in less than 30 minutes. No bloody knucles either. I think it was mostly due to this tool I picked up off ebay. I used that one with a few other socket sizes that I bought locally. I'll have to measure all the sizes I had. The socket was bored out and fit all the way on the plug to break it loose. Then I would use a socket a bit longer to finish removing. I spent more time dropping plugs in the engine and greasing them with anti-sieze than anything. Yes, I tried using rubber hose to get them started. I think next time I'll use an old plug boot. The only thing I removed was the three ASR bolts to get it out of the way. I also bought the sidewinder tool for this job. I tried it on one plug and threw it aside. It is too bulky and difficult to turn to really be usefull. I think some have had luck with it on the older C4's. It was a waste of money for me. This job really was a whole lot easier then I thought it would be. Anyways I just wanted to share how usefull the right tool can be. A lot of people have rigged up similar tools or purchased the wrench seperate. Next time I'm pretty sure I can do it in under an hour. By the way I do have headers but from what I've read it doesn't make much of a difference.
I couldn't believe I had them out in 30 minutes. It took at least another hour to finish up though. I took my time regapping, greasing, and installing the plugs gently. My little magnetic pickup tool came in handy several times, picking up plugs down under the engine.
I couldn't believe I had them out in 30 minutes. It took at least another hour to finish up though. I took my time regapping, greasing, and installing the plugs gently. My little magnetic pickup tool cam in handy several times, picking up plugs down under the engine.
Rick, rachet wrenches have saved my butt a few times. I tried the wrench and socket setup but the passenger rear spark plug on the LT1 just won't have it. Battered and bruised, wheel off, wheel skirt removed and didn't make it go any faster. After using rachet wrenches, short socket, etc... I was amazed at the time difference. Right tools make a difference. Thanks for providing the info
Accelerated Slip Regulation
It is the black plastic covered unit on the Drivers side that says ASR. The ASR system will kick in when your tires begin to lose traction. It will apply brakes and manage spark and throttle until the slip is not detected any longer.
I was looking in my engine bay (93 LT1) today trying to figure out why the plug socket needed to be cut down. Even at plug #8, if you use a standard 5/8 plug socket with a 3/4" flex gearwrench, you shouldn't have any problems...
Why the cut down socket???? Is it just for headers?
