C4 LT1 Rear Mounted Turbo Update (pics)
wow...very cool! A few question for ya and others on the forum who know.
1: are our stock ltx 10.4 to 10.8 engines too high in compression to get a worthwhile increase? If the 450 rwhp is true, then of course it is worthwhile. I just thot that was too high already. I know that the charge temp decreases because of the distance which is nice. Is that what makes it ok w/o an intercooler?
2: What about the guys like me with just a cam? Specifically the hotcam on the lt4 engine...I don't think this cam is designed for boost but how will it work out?
3: What about guys with modified ...ie higher compression ratios. Will they see a benefit or will they risk detonation..
4: How is detonation controlled? Is our knock sensor system sufficient?
5: Any underhood developmental shots would be really really cool!!! as would more under the car pics
And Like everyone else, I hope this can be installed for a reasonable price...LOOKS AWESOME. I think setting a lower price would sell a lot more units and thus give you more potential profit...especially for most of us C4 DIYers.
thanks!
Sam
thanks!
Sam
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
Street driving and track use (throttle on/off/on/off/etc.) is where lag issues will rear their ugly heads.
All that piping cannot help but exacerbate turbo lag...the issue will be "just how much?"
Anyone can throw wild-a$$ guesses and speculation around like they are fact.....just don't expect everyone to believe them.
Until an inbiased party verifies some of these "too-good-to-be-true" claims, I would be (and am) skeptical.
Larry
code5coupe
thanks!
Sam
thanks!
Sam
Lag is never an issue in drag racing, where only full throttle/high rpm is used.
200 degrees? 50hp?
Larry
code5coupe
200 degrees? 50hp?
Larry
code5coupe
Thanks for the input.
You bet... the system will be verified by several unbiased parties. Probably more testing then will absolutely necessary. As always there will be non-believers and we know that. These people will just have to drive one and see if they like it or not.
As far as claims from us, there are Zero. The systems will do what they will do and no more. We do have some basic expectations based on other STS systems but that’s about it...
After we complete the project all the data will be published and the cars will be available for interested parties.
As far as skepticism, at this point without any claims it might be more appropriate to be hopeful… Skepticism may follow…
Cheers,
Ron
I've read a few articles on the STS Turbo system and I also saw one of the systems featured on Horse Power TV. Everything I've seen and read has stated that there is no lag. It is reported that there is a slight drop in PSI, but the cooler running turbo is supposed to make up for that slight drop...not exceed it.
We are utilizing parts from the universal kit and are making a C4 specific kit... We don't think there will be much to change from the LT1 to the L98 or even the LT4.
The TT LT5 kit is the most challenging and it's almost done…
RH
RH
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
#33
I ment to say "about" 200 degrees.That is what joe on Horsepower said.I have seen that same episode about 4 times.It's not the gospel,just what he said.
#34
I'm wondering why they chose to go with a Single turbo, vice a dual on the C-5/6's (Other than cost)? I thought the dual turbo's were what helped manage the reduction of turbo lag in those setups, but please correct me if I am wrong. Either way I'm VERY interested.
#35
St. Jude Donor '10
200 degrees? 50hp?
Larry
code5coupe
200 degrees? 50hp?
Larry
code5coupe
Funny thing is Ive actually owned a twin turbo Corvette (unlike most who talk about lag) and it had literally no lag issues at all if I was acclerating from the correct gear. Lag happens on small motors with huge turbos. A properly sized ball bearing turbo should drive very smooth....just like my car did.
#36
Received 3,043 Likes
St. Jude Donor '05
This is going to save a whole bunch of guys the headache and hassle of all the H/C packages when they can bolt one of these on, tune it and turn the key. All the power, driveability, etc etc. You just pay it in one chunk, thats all.
Boosted cars are awesome! If youve never driven/ridden in one youll become a believer, I know I did.
#37
BUT.... turbo lag is failure to give immediate response, especially when you are NOT in the ideal gear/at the ideal rpm.
You can take the most outrageously-sized (large) turbo and, if you keep the engine boiling at 5000rpm under a good load, you may not experience any discernible lag. Conversely, you can take a well-matched turbo on a well thought-out and designed system, and can get it to exhibit lag under the right set of circumstances.
I see the rear mounted turbocharger as presenting a different type of "lag", one where response is compromised because the turbo has to pressurize such a large volume (an extra 15' or so of large diameter piping?). The larger the volume, the more time it takes to pressurize it; simple fact. The question in my mind is how much extra time will it take?
Will it be seconds or milliseconds? I don't know. Who does know??
I realize any turbo setup is a compromise. The rear-mount gives up a little efficiency for the sake of ease-of-layout. (If all that distance means lowering of charge temperatures, then it also has to mean lowering of exhaust temps by an even larger amount because of the higher exhaust temps, which will negatively affect turbo efficiency)
The rear-mount may very well be the best way to achieve an affordable turbo for the Corvette.
But no lunch is free. What does the rear-mount turbo give up? It has to give up something, you can't avoid that. (every system gives up something in order to get something else...) That is my question.
I hope this works out stupendously. Good luck to STS and the crew there. I'll be watching this closely....
In the meantime, and until speculation is replace by hard, impartial data, I'll remain both skeptical and hopeful!!
Larry
code5coupe
#38
Large Impressive Member
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Rhanselman, do you think this would be too much for an all forged 388 @ 11:1 CR? Do you have numbers, rating, specs etc. on the turbo unit? Is boost easily adjustable?
#39
Now, that sounds SOOOOOOO easy!
STS should hire you to write the ad copy for this , cuisin'.
Out of the thousands of Corvette owners on this forum, how many have the ability to "bolt it on" properly and "tune" it, before driving off into the sunset in a cloud of tire smoke?
Three people? Five?
Ya' gotta' be realistic, man. Horsepower is seldom cheap and it's never easy.
Larry
code5coupe
Three people? Five?
Larry
code5coupe
#40
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Maaan, I gotta have one of these!!!!
So how is the turbo unit lubricated?
