Do you recognize these 94 LT1 peices?
I am rebuilding a 94 LT1 coupe - These are out of the front end I think - - -Does anyone know where they go? (lug cap is in there for size reference only)
i think they are the clips that the spark plug wires clip on to... if im not mistaken they go on the sides of the motor too.. but then again i could be mistaken
2021 C6 of the Year Winner - Unmodified
I just went out and looked at my 94 and they indeed appear to be part of the sway bar bushing holders. These are the inside brackets, the sway bar goes through the rubber/poly bushing and then another metal bracket on the outside covering the bushing and this bracket. Bolting through both metal brackets.
thanks so much. I bought this car from a forum member two years ago. He only had it two weeks and he slid off the road and lightly (looked like) the front. The damage wasnt that bad, but to fix it right I had to diss-assemble the suspension and front end all the way to the fire wall . I also sent it out to a shop for some welding, anyway, between my other corvette projects, its been sitting and only been worked on as time permitted, now I am getting "close" to finish and its hard to remember every little peice. I really appreciate everyones input!
Here's a picture I just took of the part in question.
It's the white colored (dirty) part on top.
