C4 Turn Signal/cruise Lever
Does Anybody Have A Procedure For Replacing The Turn Signal/cruise Lever On A 88 C4 That A Dummy Like Me Can Follow? I Assume The Steering Wheel Has To Be Pulled. Thanking Anyone Who Responds In Advance!
I don't have a written procedure,, but you have to pull the wheel. You need a wheel puller and the tool for removing the wheel lock, both pretty cheap at a parts store. It's fairly straight forward, just time consuming. You can use fishing line to snake the wires if you need to remove them.
