mobile one?
Old Jul 12, 2007 | 01:03 AM
~Cobra Killer~'s Avatar
~Cobra Killer~
Is synthetic bad on a L-98 motor? I have been using regular dino oil but all the gaskets have been replaced so there shouldn't be a problem of leakage and I know it cleans out all the sludge build up. Would Mobil1 hurt my car if I switched to synthetic? Repezard just said so. Thats not a good thought.
Old Jul 12, 2007 | 02:07 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If you don't use Mobil 1 your engine will sieze on startup and catch fire.
Old Jul 12, 2007 | 09:14 AM
rws.1's Avatar
rws.1
The perils of switching to synthetic and back are nothing but an Urban Legend...
You can do it... if you want.
Generally speaking synthetics do 4 things better than mineral oils.
1. Flow better at low temperatures ( the molecules are engineered to be the same size/shape) better flow at low temperatures means faster lubrication upon start-up.
2. Better lubrication at higher temperatures gives more protection in engines known to run hot.
3. reduced tendency to shear thin menas it stays in grade longer. this leads to extended drain capability.
4. higher levels of detergency to prevent soot and varnish build associated with longer drain intervals.
There is nothing inherent about that that can damge your engine. Switching back and forth is NO issue.
HOWEVER, if you are running a older car with pre-existing leaks, the higher detergency will clean your engine and will remove the sludge and varnish that MAY be minimizing your current leaks. Therefore pre-exisitng leaks may leak more....
That is the only downside to using a synthetic, other than price.
Old Jul 12, 2007 | 09:29 AM
rws.1's Avatar
rws.1
Sorry,
I meant to add that I use fully Synthetic in my L98.
It keeps the engine clean and there are no leaks. It had Mobil 1 in it when I bought it 4 years ago , but I swithced to Pennzoil Platinum becaus eof its impressive low wear metals results and its avialablility at Advance Autoparts in both spring and fall BOGO offers that brings the price down to $3/qt.
Old Jul 12, 2007 | 10:47 AM
CentralCoaster
That is the only downside to using a synthetic...
And that is a HUGE downside. Replacing all the seals in your motor (intake, front/rear mains, oil pan, etc.) is not fun.
Old Jul 21, 2007 | 06:06 PM
fixit's Avatar
fixit
I have a '94 LT1 and from what I've read most OTC, over-the-counter, oils have been so dumbed-down lately. You really have to do your research to find a decent performing brand or product.
My search has led me to the following as very good for an LT1:
Castrol 0W-30, Made in Germany - (European Formula) only available thru internet order or from outside USA.
Pennsoil Platinum 5W-30 (European Formula) again buy over the internet or outside USA.
Mobil1 0W-40, European Formula, this one you can get almost anywhere.
Notice all are European Formula oils. That seems to be what separates them from other common, dumbed-down oils.
Mobil1 in the other grades, 5W-30 10W-30 are not as performance oriented as the 0W-40 is.
Old Jul 22, 2007 | 01:09 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
The "dumbing down" to which you refer is likely a result of the fairly recent introduction of the API SM/ILSAC GF-4 oil specifications, which limit phosphorus to 0.08%, or 800 ppm. As the primary anti-wear additive that most companies have been using for years is ZDDP, which includes phosphorus, the new rules have limited the anti-wear additives in most oils. That said, most European oils meet ILSAC GF-4, so there isn't much difference there anymore either.
I'd also note, that I don't think any of the oils you listed, with the possible exception of the German Castrol 0w30, are labeled to meet GM Standard 4718M for the Corvette.
AMSOIL does sell a European spec oil, the AMSOIL Synthetic 5w40 European Motor Oil, but as I mentioned above, due to similarity between the API SM and ILSAC GF-4 standards, this oil, like most others on the market, meet both requirements. But, as an FYI, this oil is made in the USA and doesn't have to be imported from Europe. Note however, that it too doesn't meet GM Standard 4718M.
I use AMSOIL's best API SM oil in my 2006 CTS-V:
AMSOIL Series 2000 0w30
For my Corvette Z06 on the track, I use an oil which doesn't meet the API SM standards:
AMSOIL SAE 10w40 Formula 4-Stroke Marine Synthetic Motor Oil
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jul 22, 2007 | 04:03 AM
CentralCoaster
It sounds like it'd be much easier to be using these compromised oils that are readily available, and spend the effort looking for a good additive that will make up the difference. I assume these additives are not regulated much or at all by the smog *****.
Old Jul 22, 2007 | 04:36 AM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Old Jul 22, 2007 | 02:07 PM
corvette1271's Avatar
corvette1271
Default amsoil
subdriver......i use amsoil in most of my vehicles. iuse mobile one in the rest. my 94 lt1 uses series 2000 with an eao 25000 mile filter. it runs great......i am here in stanwood, wash........just north of everett....
Old Jul 22, 2007 | 02:13 PM
CentralCoaster
How often do you change the oil?
How often do you change the filter?
What is your oil pressure before and after a filter change?
Old Jul 22, 2007 | 03:08 PM
C66 Racing's Avatar
C66 Racing
That's the same oil and filter I use in my 06 CTS-V, which is my new daily driver. Lots of fellow forum members in the PNW. I got to a Vette get together about a year ago over in Lynnwood, but haven't had time to get to another one. I'd like to though as I have a few free weekends left this summer. I need to go check the local Vette club sites for get together dates...
Old Jul 22, 2007 | 03:52 PM
  #33
rockerdudez06's Avatar
rockerdudez06
I love WALMART!
Old Jul 22, 2007 | 04:01 PM
  #34
Blak Z06's Avatar
Blak Z06
Originally Posted by glass car
That would be my choice.
Why change??
Old Jul 22, 2007 | 04:31 PM
  #35
Mekanic's Avatar
Mekanic
Mobil 1 5w-30 and a Wix filter every 5k or 1 year.
The reduction in ZDDP really only had an extensive effect in flat tappet engines. But if it is a concern to you, go to your local chevy dealer and pick up a bottle of G.M E.O.S.
It contains all of what was removed from the oil and mixes well with synthetics, unlike other additives like STP which I would not mix with a syn oil.
Old Jul 23, 2007 | 11:05 AM
  #36
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
I use the Mobil-1 5w30 synthetic and the AC Delco oil filter. No worries.
Old Jul 23, 2007 | 11:38 AM
  #37
redwing76's Avatar
redwing76
My E320 takes Mobil1 per the factory manual, and Mobil 1 autotrans fluid.
Oil change and the A service, with the trans was $265.00
Mobil 1 is factory fill for the Corvette, Mercedes, Porsche, Aston Martin, etc.
Personally I don't like 5-30.
To mobile one?
Old Jul 23, 2007 | 12:11 PM
  #38
80sRule's Avatar
80sRule
My 87 runs mobil 1 and has never leaked oil. But, you're dead right. I have seen friends cars that have leaked on a synthetic oil.
All of my families other car's engines(cars bought needing rebuilds) were rebuilt w/ new seals and gaskets, no leaks on the ones running synthetic.
Old Jul 23, 2007 | 12:22 PM
  #39
redwing76's Avatar
redwing76
A oil leak sure stops a lot of rust, new cars, no leaks and everything is rusty.
Give me a leak everytime.
Old Jul 23, 2007 | 12:40 PM
  #40
Aquaman92's Avatar
Aquaman92
Once a year 5w30 and K+N filter I drive around 2,000 miles a year
