What to do?
Old Nov 25, 2007 | 10:21 PM
lil_Mike's Avatar
lil_Mike
Default What to do?
well i put all my intake together and was putting the thermostat housing on and as i was putting one of the bolts in (not using much force) it snapped. i really dont want to take the whole manifold off to take it to my shop to get it off. is there anything i can do at my house to get it off. would it be ok with 1 bolt and alot of "right stuff" gasket/sealant.
i tried vise grips but it was jsut stripping the bolt.
Old Nov 25, 2007 | 10:39 PM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
I doubt that you can get it to seal without both bolts....you just need to get that thing out of there. Have you tried a propane torch and heating up the bolt? That might do it for you.
Old Nov 25, 2007 | 10:42 PM
lil_Mike's Avatar
lil_Mike
someone jsut told me that that might work.
Old Nov 25, 2007 | 10:44 PM
Final Effort's Avatar
Final Effort
And use a stud wrench.
Old Nov 25, 2007 | 10:54 PM
drippingwithgold's Avatar
drippingwithgold
I use the MAP gas, its hotter and with a good set of vise grips it should come right out. Walmart sells it too, it in a yellow cylinder and can be used with the propane torch head. You need both bolts.
Old Nov 25, 2007 | 11:02 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Try a easy out, and lot of penetrating fluid to soap it.
Old Nov 25, 2007 | 11:33 PM
Calderone's Avatar
Calderone
you can weld a wrench to it and start turning turning
it will get out from there yes or yes !
Old Nov 26, 2007 | 03:55 PM
badabing9's Avatar
badabing9
a few options; map gas is the way ta go to start out with. next, ya don't heat the broken stud as it will expand only making it tighter and harder to get out, you heat the area around it and then with a pair of vice grips or channel locks, grab the broken stud and start turning - it should come out.
if it doesn't, you could drill a hole (or series of holes) into the top of the stud (dead center) and if you are patient and Careful, you can "remove the weak remnants" of the broken stud.
Old Nov 26, 2007 | 04:04 PM
Aardwolf's Avatar
Aardwolf
Can't you just put two nuts on it and turn it out?
Old Nov 26, 2007 | 04:07 PM
All2kool's Avatar
All2kool
Using a Dremel, cut a notch in the top and then use a screwdriver to remove it.
Old Nov 26, 2007 | 04:19 PM
Jims79's Avatar
Jims79
but you may have crossed threaded the bolt in that case you can tack a nut onto the bolt & turn it out. then rethread the hole G/L
Old Nov 26, 2007 | 04:43 PM
blkc6z51's Avatar
blkc6z51
Try this.
http://www.brokentap.com/easy-outs.html
Old Nov 26, 2007 | 04:50 PM
mdlfcrss's Avatar
mdlfcrss
drill a hole down the middle of the broken bolt, then using an easy out and lots of rust bust, slowly work it out with a back and forth motion. Turn it out a half a turn, then back a quarter, then another half, etc... I've done this in the past and it works. You will need either new or very sharp drill bits and a very good easy out. Good luck.
To What to do?
