6-speed Concern/Question
Old Nov 29, 2007 | 10:12 PM
tdf's Avatar
tdf
St. Jude Donor '11
Default 6-speed Concern/Question
I drove a nice 89 C4 Vert this afternnoon that I'm contemplating buying. I noticed a couple times when going from 1st to 2nd the shifter wanted to slide over to 4th instead of 2nd. When I tried to correct it there was resistance and a slight grind insued (nothing bad).
Is that a shifter issue or something internal to the tranny. I drive nothing but sticks so I don't think it's the driver in this case.....could be....but not likely!
The car otherwise seems very healthy and immaculate for an 89.
Old Nov 29, 2007 | 10:19 PM
Fast Doc's Avatar
Fast Doc
Sounds to me like the CAGS has not yet been disconnected. One way to tell would be to see if it wants to shift 1 to 4 under hard acceleration, or at greater than 20 MPH. Normal CAGS would allow a smooth upshift, if not there may be a linkage or transmission issue.
Old Nov 29, 2007 | 10:20 PM
pianoguy's Avatar
pianoguy
Sounds like CAGS (Computer-Aided Gear Selection) - I'm not sure what year they introduced it. At a certain combination of RPM or speed, you are forced to shift from 1st to 4th (real annoying), and can damage the transmission if you try to shift into another gear. A light should appear on the dash at this time, also. There's a $30 gizmo you can buy to defeat this "feature".
Old Nov 29, 2007 | 10:49 PM
tdf's Avatar
tdf
St. Jude Donor '11
Default Oh - Thats Likely the Reason
I had forgotten about that feature in the 6-speed. Never owned a corvette 6-speed myself, but I do remember reading some threads with that feature in them. I feel less concern now. Thanks for the education.
Old Nov 29, 2007 | 10:53 PM
85 500 horse's Avatar
85 500 horse
When attempting to shift into 2nd from 1st, if you're experiencing more of a resistance than a slide, it could be the synchro gear needing replacement. When the synchro gear needs replacement, the telltale signs are grinding and difficulty shifting into the problematic gear. It's not a cheap fix. If the seller is a dealer, tell the salesman you want it repaired. If it's a private sale, make sure you knock off at least $500 from the asking price. It could very well require more money to take care of this problem, if it's the synchro.
Old Nov 30, 2007 | 11:25 AM
Aspect's Avatar
Aspect
Navigator
I hear what you are saying. But if he attempted to go back into first after CAGS pushed him to 4th. There could be a normal grind because he didn't double clutch it to get the syncro's in line.
Description of Double Clutching
Originally Posted by Article
But even with synchronizers, a driver trying to shift from fifth gear into second could have some trouble.
Old Dec 1, 2007 | 02:03 PM
tdf's Avatar
tdf
St. Jude Donor '11
Default Same Car - Another Question - Seats ??
Since this is a thread I started, maybe an unrelated question will be tolerated. Same car! Has anyone ever seen an 89 Convertible with cloth seats. I have no idea if they are factory or not?
Old Dec 1, 2007 | 02:35 PM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
Yup, cloth seats were available up to 1994 when leather became standard. I don't think they are very common, but they were available.
Old Dec 1, 2007 | 04:36 PM
illenema's Avatar
illenema
Default Skip Shift
Yes my 94 had that dam skip shift. What a pain. I ordered a pcm from PCMFORLESS had the skipshift programmed out,had the fans programmed to turn on at 210, and a performance tune. Lower temp allowed more timing. much faster throttle response on the pcmforless. I kept the stock pcm to switch back and forth. There was a difference.
To 6-speed Concern/Question
