Gas tank woes ! Help
My car has been stored for 6or 7 months their seems to be a large mound of somthing in the bottom of my gas tank anyone knows what it is and how can i get out, sorry to say but i need to know the easy way to clean it
Ohhh. Remove the gas door assembly, (four torx screws), and then CAREFULLY remove the rubber boot, it will probably be brittle. Then you will see the fuel pump assembly. Disconnect the three hoses, and remove the ten or so 10mm bolts that hold the unit in. Carefully lift and twist the unit until it lifts out. NOW BEFORE DOING THIS, you need to determine what you are trying to do. the big lump you are looking at, I now assume, is the fuel pump assembly.
No what I am seeing is a large pile if you will of crape, the fuel pump is coated with like a carbon rusty looking stuff the sediment in the bottom is 2inches thick under the pump,I need to try to clean it in the car after taking the pump out,im just not sure how to start can i siphon the crud out? is their a pump that i can buy to suck it out?
Get a suction tool at Harbor Freight or at a parts store. You can also get a hose for an outboard motor (with pump ball) and use it to siphon it out.
red vet man (05-10-2016)
Keep in mind that there is a plastic sump in the bottom of the tank. It's glued to the plastic liner. When the gas tank is low this sump captures enough fuel to keep the fuel pump from starving when going around turns. If you dislodge it you may not be able to glue it back down. This is probably why you're seeing a mound of crap below the fuel pump, it's in the sump or you're just seeing the sump with fuel in it. Just be careful you don't bang it loose.
Art
Art
Art
Art
