Rhino ramps
Rhino ramps
Hello everyone,
I've read some posts where some people swear by their rhino ramps.I'm thinking about going out and buying a set maybe tonight or tomorrow.My question is,will rhino ramps raise a 'vette (87), high enough for an average sized person (who can still suck in his gut ) to get under,or just high enough to get a jack under for placing jack stands? Thanks to all who reply.
tankman
tankman
You could probabally fit an 8 gallon keg underneath the car without the tap in. Just be sure to put some 2x4s down so ya can get on the ramps instead of pushing them out of the way with your bumper
I have a pair, and they work OK for me, but I'm fairly slim. I have to put a 2x10 in front of the approach to keep the spoiler from scraping. When I put my headers in and pulled my exhaust earlier this spring, I needed more working room, so I jacked up the front after it was up on ramps and added another 2x10 underneath, and also jacked up the back and put a couple of 2x10's stacked under the rear wheels. I've also seen people jack the front end up after it's on the ramps and flip them around so that the approach is out of your way. Anyway, for the price, I'm happy with the use I've gotten out of them. I'm not a big fan of jack stands for some reason.
I can't get a floor jack under my car without using the the ramps. I get lots of use out of them for oil changes and minor things like that. Any more serious work under the car and jackstands are required.
Well,I bought a set & should have checked the dimensions first.They don't have the height of my old steel ramps.I think I'll take them back in the morning and start looking for something else.
I already got them.I will be looking for something else,but am not ready for the quick lift.I saw some aluminum mini-ramps advertised somewhere.I'll see what the scoop is on them.
St. Jude Donor '05-'06
I have see some really neat 2 piece aluminum ramps wish I could remember where. They were pricey though. They had a little more height but all ramps are pretty much for changing oil which is fine they do make that job quick and easy. Never seen one you could slide under with a dolly on.
I did read a funny/scary thread on someone trying to back up on them he spit them under the car in front of the rear wheels.
I read that post also about the ramps flying out.I don't do much except oil changes,spark plugs,water pumps,and coolant changes.I've been reading about the Different procedures for changing coolant & don't know which one to go with.I recently bought this '87 and am in the process of changing out fluids.
Rhino Ramps
I had a car fall on me, that was supported by crappy stamped steel ramps when I was 19 years old. Fractured my hip and and two vertebrae. I was lucky it didn't kill me. The attending doctor in the ER said that most victims of cars falling on them are from poor jacking or ramps not properly secured, and most people don't live to tell about it like I did. Most that die are from suffocation, because they can't raise their chest to breathe!!!
Yes, we did some stupid stuff and were not as safety conscious as we should have been, but I'll never trust another ramp in my life. I still get under my car all the time, but it is supported by strong jack stands, and I kick the **** out the car before I go under to make sure it ain't going anywhere.
Just keep it in mind, because it only takes a second and then you say "Oh ****".
tankman
I installed my cat-back exhaust using plastic ramps. When I was finished and drove forward off of the ramps I spit both out the back about 20' down my driveway. When using on the rear are you supposed to drive forward on them or back up on them?
