Headlight adjustment (opposite direction adjustment)
Old 06-26-2008, 10:33 AM
CStewTAMU
CStewTAMU's Avatar
Default Headlight adjustment (opposite direction adjustment)
I know there are other threads on headlight adjustment, but they only talk about how to keep the higher portion of the headlight lid from being too high-just adjust the rubber stopper.
What if your headlight is too low where the stopper is? In otherwords, if the headlights are closed, the side of the headlight door closest to the bumper if flush, the side closest to the windshield is sunken in about 1/4 of an inch.
Basically, I need to adjust my headlight the opposite direction all the threads talk about. All the bolts that hold the assembly in place are tightened.
Old 06-26-2008, 12:10 PM
Demonic85
Demonic85's Avatar
You have the opposite problem from me. The front of my headlight sits too low and i've tried adjusting it like a million times
Old 06-26-2008, 01:21 PM
CStewTAMU
CStewTAMU's Avatar
I thought the rubber stopper would fix your problem. Weird.
I think I might have just losened everything on mine when I took myheadlight out. I had to hit that pin thing you have to remove with a hammer pretty hard. That pin did not come out without a fight. I might have bent something slightly in the process.
Old 07-12-2008, 01:19 PM
Demonic85
Demonic85's Avatar
Thats normal for the pin to be stuck in there pretty good. My headlight was sitting too low even before I replaced the gears.
To Headlight adjustment (opposite direction adjustment)
Quick Reply: Headlight adjustment (opposite direction adjustment)
