Do the outer side window seals have the felt 'scraper' riveted to them?
My drivers side seal is scratching the snot out of the glass. If so, which is best ....OEM or aftermarket?
Mike
I did mine a couple years back. Got OEM from Chris at Superior. No problems at all replacing them.
The only felt pads on my doors are mounted in the door, not part of the seal. I loosened mine to make the work on the seal a little easier. The pads help guide/secure the window going up and down I believe.
I replaced mine in about an hour (to a little extra time to clean all of the electrical connections while I was at it, darn rear hatch switches now work !!! ).. got mine from Ecklers' No problem yet, but I am planning on replacing all of the window/door seals before winter comes.
Are those 'pads' an OEM or aftermarket replacement part? Mine are riveted onto something or other, and the damned rivet let go and it swings down when I send the glass down. The 'pads' if I understand right, are NOT part of the outer window seal kit?
Mike
The outer seals are riveted, but the rivets are nowhere near the glass, unless your sweeps are hanging off and bent in towards the window. Corvette Recycling has a thread in the parts section - NOS GM outer seals for $30 ea, free shipping. They also have NOS felts for $7 ea.
I used #14 sheet metal screws to install mine. You'll have a hard time finding large flange rivets to rivet them back in.
So you don't have to use screws, thats why. Are the screws OEM?
The aftermarket outer window felts are the ones everyone complains that the clips don't line up. Screws or rivets doesn't matter, they both work and you're never gonna see them.
NAPA has the rivets, that's where my buddy got his.
Originally Posted by miks139
Ecklers has the aftermarket ones with the rivets included
That's the kit I bought and it is crap.
Originally Posted by C4boy
Why would you buy aftermarket when you can get original GMs for the same price?
Sometimes aftermarket can improve on OEM also.
screws are not OEM
That's what happened to me. They look much better than the tore up originals but they are not perfect.
GM must have improved them over the years since my '95 with over 140,000 miles(bought with 57,000) and kept outside for many of the years I've had it are in perfect shape.
My '93 had 36,000 miles when I bought it and the outer seals were already shot.
screws are not OEM
That's what I wonder about in buying the OEM's....especially any of the NOS mentioned above.
Which ones are you getting???? The good composition rubber of the 95 year? Or the poor composition rubber of the previous years?
So, we all know the OEM will rot and crumble. Does the aftermarket do this, or does it stay pliable?
The PO put in aftermarket seals on mine 3-4 years ago, and they look good. I plan on removing them when I get it painted, but was thinking of swapping in OEM seals. ?? I may just reuse the old ones since they still look good. Though, I do have some scratches on the outside of the glass.
Mike
Aftermarket crap in NEVER as good as OEM stuff.The rivets you need shouldnt be too hard to find,I did this years ago and didnt have a hard time finding the rivets.The most important part of this job,wrap a piece of tape around the drill bit,this will keep you from drilling a hole through the door.
If I got new OEM outside strips, how long till they start cracking? The PO put in aftermarket ones 4-5 years ago, and they look good and are still flexible.
I put aftermarkets on my car. Not sure of the manufacturer, but it was a package deal on Ebay with inner/outer door seals for around $100. The fit was good and the install was easy. I can't comment on the durability, but I can't imagine it'll be any worse than the crappy GM ones, which on my car were falling apart at about the 8 year mark
