C4 Weights and Info
#43
OK! Added a TON of info (car weights, seats, tires, wheels...) as well as adding the sources of information. I have to go through my PMs to get the rest of the sources, so that'll be up sometime soon.
#44
Thanks for doing this!
I've long used and been impressed with the C5 weights thread. I thought of starting one for the C4 section but it's a lot of work! Thanks again for the effort.
#45
Should be a pretty useful list once I get done with it! (does stuff like this ever end?) That's what vacations are for, right?
Added a bunch of tires and about to PM a mod about moving to Tech and stickying, so don't fret if it disappears!
#46
I know there is a discrepancy between my thin spoke weight and what was reported in the C5 thread. When I weighed the rims I knew others reported 20# so I carefully reweighed each rim and still got 18#. Either my scale is off or theirs is. My weights are from a cheap scale but I was careful with placement and adjustment. I have six of these rims and have tires on and off all of them through track use.
#50
Yeah I noticed that, so I just left all of them on there. There are discrepancies within the C5 list as far as the front wheels go (16 lbs vs 18 lbs) also. I can't vouch for either, which is why I just put it all up there with sources.
#51
New
PS rack plus inner rods, no ball joints 15 lbs
PS pump with pulley 5 lbs
ball joints 1 lbs for both
alternator 10 lbs
injectors 2 lbs
throttle body 2 lbs
trans cooler, B&M plate 11x10" 2.5 lbs
lifters, all 16 hyd roller 4 lbs
Frisbee early 9 lbs - late 3.5 lbs
Spare tire and carrier 40 lbs
air pump and parts early 10 lbs
cruise control parts 2.5 lbs
evap system 2 lbs
windshield washer 9 lbs FULL
stock 12" torque converter 45 lbs
9.5" converter 30 lbs
cat 10 lbs
Magnesium valve covers are 2 lbs
Radiator 9 lbs
A/C condenser 5 lbs
A/C compressor 21 lbs w/pulley
700r4 135 lbs
dizzy 5 lbs
EGR valve 1 lb
Underhood lights 1.5 lbs
intake with K&N filter and cut lid 6 lbs
crank 50 lbs
bare block 143 lbs
head 22 lbs
piston 21 oz each / 595.339 g
cam 9 lbs
connecting rod 603-604 g, big end 424 +/- 2 g, pin 179 +/- 2 g
rim 17x8.5 sawblade 19 lbs
rim A mold 21 lbs 11" - 9 1/2" 20 lbs
cargo shade 8 lbs
OPTIONAL EQUIPMENT WEIGHT
Custom adjustable sport seats (RPO AQ9): +16 lb. (power adjust for backrest, lateral restraints, lumbar support and back angle, special cloth trim)
Power door lock system (RPO AU3): +1.8 lb.
Leather seat trim (RPO B16): +3.5 lb. (as required; special contour bucket seat)
Removable plastic roof panel (RPO CC3): -4.0 lb. (Acrylic plastic. Lighter, blue tinted for glare and sun load control, coated for scratch resistance. Not available on convertible.)
Automatic speed control with resume speed (RPO K34): +2.6 lb. (with manual or automatic transmissions)
Radio delete (RPO UL5): -11.0 lb.
Radio AM/FM stereo (ETR) with cassette player (RPO UM6): +0.8 lb. (includes power rear antenna plus two front and two rear speakers)
Custom two-tone paint (RPO D84): +0.9 lb.
Automatic transmission (RPO MD8): +13.6 lb.
Delco-Bose premium audio system (RPO UU8): +15.4 lb. (includes specific AM/FM stereo radio with cassette player, Bose power amplified, direct-reflecting speakersone in each door and at each side of luggage area. Also features Dolby sound, dynamic noise reduction and automatic suppression system.)
Heavy-duty cooling (RPO V08): +4.9 lb. (includes HD radiator, auxiliary boost fan, and oil cooler
Electric defogger systemhatch and outside rear view mirrors (RPO Z6A): +0.8 lb. (mirrors only on convertible)
Performance handling package consists of FE7, FG3, GZ0, V01, KC4, B4P (RPO Z51): +35.7 lb. (includes left-right 16x9.5" wheels, fast steering, HD cooling, and 3.07 axle ratio for automatic.)
Automatic air conditioning (RPO C68): +2.205 lb. (automatic temperature control)
alternator 10 lbs
injectors 2 lbs
throttle body 2 lbs
evap system 2 lbs
cat 10 lbs
Radiator 9 lbs
A/C condenser 5 lbs
700r4 135 lbs
dizzy 5 lbs
EGR valve 1 lb
crank 50 lbs
bare block 143 lbs
head 22 lbs
cam 9 lbs
cargo shade 8 lbs
#53
No rush! It's to cold for to do much here. I'm in the middle of an engine rebuild so I've had time to weigh things but can't work in the cold to long.
It's interesting to note the stock piston weight, 21 oz = 595.339 grams. My rebuild is going to much lighter!
I've got the ABS removed from my track car now, it's pretty light. I'll verify the weight at the post office.
ABS system 16 lbs (ABS pump, four sensors, and computer - year '88)
#54
American Custom Ind ACI race hood 45 lbs $860
Black dog speed shop carbon fiber hood 26 lbs Clear Finish $5000 Paintable opaque finish $3750
Stock hood with everything 110 lbs
Performance AFX hood 24 lbs $1700
VFN fiberglass lists several hoods, 84-96 Flat Pin On Hood $299.00 13 lbs, 84-96 3" Pin On Hood $315.00 13 lbs, 91-96 large stock tilt type hood (pin-on only) $645.00 18 lbs
Toledo Pro fiber glass 33 lbs $800
#58
