flashing lights on climate controls and no A.C
Does anyone no why the indicator lights on the buttons for my climate controls are flashing?
My mechanic recently changed the heater core and since i got it back i have no A.C and the lights on the control buttons flash sometimes???
Normally this happens when its low on Freon. But pulling the codes from your ALDL port under your steering wheel with a paper clip can get to the codes. This also could be a head unit issue and miswiring since the top end of the dash needed to come out to replace the heater core. Lot or wires and hard lines back there
I agree you have to pull the codes but not from the ALDL connector where the codes come from the CCM and ECM/PCM. You need the get the codes from the (A/C) Control head. Use this link to get the codes.
http://www.idavette.net/tech/c4diag.htm
The mechanic probably didn't hook the door actuator motor back up, or at least some wire for the A/C. Considering what I went through to have my A/C working properly again (looooong story), I say it's the door actuator motor not being hooked up. Should be an easy fix. Does the heat still work?
LS/MFT
The new heater core works fine but no A.C,i am going there soon with all the info everyone has givin me thus far and i hope we can get this fixed.I will fill everyone in when i get back!
