Battery Drain
Dave
That should give you an idea where the voltage drain is....
I would recommend reading current instead, most voltmeters support this. To read current though you need to break into the circuit by putting your meter between the negative lead and negative battery post. What I did when I was troubleshooting a current draw was to get a long speaker wire (2-wires) and attached alligator clips on each wire. That way I could have my voltmeter in the car while pulling the fuses to see the draw either stay or go away.
I was having a similar problem and was seeing 2amps being pulled with everything off...for my 96 it should be more like .03amps. Turn out my Real-Time Dampening module was shot and a bad voltage regulator had gone bad in a shorted state.
Also you really need to be careful when something is causing your battery to be dead everyday. This means current is being pulled somewhere and that device is heating up...depending on where the device is, it could get hot enough to cause a fire.
Until you find the current draw, I suggest disconnecting the battery when possible. Something draining the battery overnight means it's drawing a decent amount of current.
Not sure about an 89, but I also had fuses under the hood too by the battery, so don't forget about those if you have them there too in your model year.
BTW...you have confirmed that you don't have a bad battery?
