Seat replacement
Old Aug 31, 2010 | 08:15 AM
auskey's Avatar
auskey
8th Gear
Default Seat replacement
Have a 88 Conv with sport seats. My question is can you swap over to a standard seat?
whats every one's thoughts.
any help would be appreciated.....
Old Aug 31, 2010 | 09:13 AM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
I don't see why not
Old Aug 31, 2010 | 10:41 AM
ejscarfo's Avatar
ejscarfo
You can swap over, but be prepared to change out the seat buckets too. The recline feature in the sport seat is motor driven, the standard seats are not. I would think if you set the angle of the recline first, then disconnect it all and install the standard seat pads, you should be ok. Check to see if the seat back and bottom buckets will mount the standard foam.
To Seat replacement
