94 "Service ASR" Light
I am relatively new to this site but need help with a recent problem.
Recently had service work at dealership in which Brake booster, fluid level sensor and a flush of the brake fluid was completed. Upon receipt service asr light comes on consistently usually after hitting rough road or bumps. Sometimes this is paired with a check engine light and the auto trans shift points are removed and car shifts roughly. Car can be shut off then restarted and indicator light goes out.
Is this a problem with recent work that I should bring back to dealership or should I start looking elsewhere. I have not removed codes as of yet.
Any help would be greatly appreciated.
thanks
thanks
Look in the master and see if they filled it with enough brake fluid.
See if they mounted the ASR box and its connectors correctly.
Good Luck
Good Luck
