95 Antenna mast will not go down...
Smokin' BBQ Member
Once the radio or engine is turned off. Anyone have this problem and a fix? Thanks.
Happened to me a couple of years ago. I dribbled a bit of light oil down the mast, and its been fine ever since.
Not sure if yours exactly the same, but I'm having some sort of the same issue.
Mine does not go down or up, I hear the motor but nothing happens so it's just sticking out right now.
I got lucky and was able to just pull out the old mast & ribbon and feed the new one in without having to pull the motor. Took about 10 minutes and has worked great for about 5 years now. If you get a new mast be sure to get the antenna mast nut socket with it.
in doing this please. I have this same issue. Stuck in the "up" position.
THANKS. 10 MINUTES!
Next have someone turn on the radio so the antenna motor wants to extend and simply pull the old mast and ribbon up and all the way out.
Take the collar off the old antenna and put it on the new one. Insert the new ribbon while someone else truns the radio off and it will pull the new mast into place. If I remember correctly the teeth on the ribbon shoulld be facing to the outside of the car. Once the new mast is on re-install the mast nut (do not overtighten) and you are done.
If there is too much debris from a broken ribbon this will not work, you will have to pull the motor to clear out the derbris. On the 95 models you have to drill out the three spots on the gear cover, earlier models are screwed together.
Hope this helps.
What is causing my brake pressure light come on and the brake pedal goes way down but, still have brakes. On it's own will go off and brake pedal returns back to normal. I would really like an answer if someone could please help
I had to take the motor down (1991) to disassemble the wheel and clean out all the old debris. My original ribbon was in many pieces. After cleaning out all the old lube and ribbon pieces, I hit it with some white lithium spray, reassembled, reinstalled and fed the new ribbon in. Been working great since.
I got to the antenna motor by going thru the rear wheel well.
