First Time Owner...First Winter... question.
I bought a 92 6 speed coupe back in September...I have enjoyed it every moment we have had dry pavement here in Massachusetts....well the snow came last week..I put the car away, in my garage and covered it up. It came with a trickle charger already connected so all I have ot do is plug it in...but my question is, how often/long should I start her up over the next few icy months? Garage is attached but not heated...so I am keepng my eye on her every day and night!
Thanks,
Shaker
Some start their cars every couple of weeks. Now the argument here is
that they say it doesn't warm the engine correctly and you could have condensation problems, cold starts etc etc.
Others, like me do what you did. Fill my tank, add Stabil and throw on
a battery charger that maintains your battery, not just any trickle charger.
Members here do both and have had no problems with either way. So
I guess it boils down to your personal choice.
But I still start mine and jiust let it run some to lube the gaskets and such. Condensation is a minor problem.
Just starting it up and letting the engine get warm is not enough. Your internal combustion engine will create quite a bit of water vapor, and this will collect in the exhaust system.
It takes a good 20 minute drive to get the whole system (engine oil, exhaust, rear end, etc.) warm enough to evaporate this moisture.
Remember, your oil temp will be quite a bit lower than water temp for quite some time. And this will create condensation, and that is bad unless you drive it far enough to burn off.
Doing once a month warm-ups in the garage or driveway until the water temp is up, will do more harm than just letting the car sit.
But if we have another winter like last year, I may have to leave the country.
Keep the ideas coming. Anyone for a Corvette Caravan to South America??
Cars were made to be driven. Drive the damn thing.
Back on topic:
When living north I covered the cement floor in the unheated storage garage with 6 mil plastic wall to wall then duct taped the perimeter. I then carpeted it with a tear out. The carpet was used for traction. If you go that route be sure the exhaust system is cool before parking. The plastic covered floor kept moisture at bay + I left a ceiling fan run on low 24-7. No rust on the rotors in the spring time after 6 months of storage.
A full tank of gas with stabil or sea foam, let it run for awhile to get the product circulated to the injectors.
Fresh oil & filter, a coat of wax & a product of your choice to keep rodents at bay.
Add 5/10 lbs of air in the tires. If you are able to push the car a bit once a month it will help to keep the tires from getting square.
After parking disconnect the battery & install a battery maintainer.
Cover the car.
To awake it in spring I would pull the plugs, pump 4-5 squirts of oil in each cylinder then spin the motor with the starter until the oil pressure was up, reinstall the plugs & light it up.
Some may disagree with the above but the system worked well for me.
But pulling the plugs to squirt some oil in? Must have been a 4 cylinder!!
Everyone I know will do anything to avoid pulliing plugs on a C4. There's gotta be another way to get that oil in there!!
And thanks to all for the great ideas.
{sound effect of yelping dog running at WOT}You could always tunnel out Sweetsie. Oh....and bring Crown Royal if you're coming.
Sta-bil, battery tender, jack stands, and mouse traps. Your baby will be fine.
Really??. For some of us it's an impossibility, hence this thread
