View Poll Results : What synthetic oil do you use
Mobil 1 Extended performance
6
10.00%
I can't answer because I use another brand
9
15.00%
Mobil 1 or Mobil extended performance
01-16-2011, 09:05 AM
Quote:
Originally Posted by
Geardo
I wouldn't use Mobil 1, go with Shell Rotella 5w-40 synthetic
I would not run 40 weight anything in the vette
01-16-2011, 09:44 AM
Mobil 1 5W30 is all you need. Your engine will work fine and last a long time.
01-16-2011, 09:53 AM
Larry/car
Not a bad oil, it's just there are better choices, the 0w-40 Mobil 1 is a much better oil
01-16-2011, 01:06 PM
I would use whatever was cheaper. Don't think there is too much difference in the two. I change oil between 5000-7000 anyways.
04-07-2011, 05:20 PM
t's possible they've tweaked the formulation since then, but in some UOA's done by Butler labs in 2005 on the 5W-30, the big differences are:
Boron - 251 EP vs 76
Calcium - 2822 EP vs 2380
Phos - 948 EP vs 678
Zinc - 1058 Ep vs 775
04-07-2011, 05:29 PM
Which one tastes best on pie?
04-08-2011, 08:57 AM
Mobil 1 in my '94! And yes, it is good on Corvette pie!
04-08-2011, 09:08 AM
Geardo
Documentation please.
4717m ,
base ,
catalytic ,
converter ,
damage ,
ep ,
extended ,
gm ,
mobil ,
performance ,
review ,
shell ,
spec ,
stock ,
switching
