1996 Coupe Base Delco Radio
Recently bought a low option and low mileage 1996 LT4 coupe. It has the base model Delco radio. I was wondering if a better set of speakers would help make it sound a little better. Of course replacing the radio and speakers would be good too, but I am looking for something low cost until the job market picks up ... and that may be awhile!
Received 6,937 Likes
2015 C2 of Year Finalist
I have the base speakers in my 94 and I think they sound great. I don't need a rolling concert
If you have the Delco-Bose system, replacing the speakers would be more expensive than you think as each speaker has it's own amplifier and is a very complicated system. The system is unnecessarily complicated and expensive. And we wonder why GM went bankrupt.
Hello
Check out some threads on this subject. You should find that after market speakers are not compatible with the bose system. If you change the speakers you should also change the head unit. The speakers should have an amplifier integrated into the unit which is why other speakers would not work as a replacement.
kdf
kdf
You guys did not read the OP post very well he has the base radio
C4 of Year Finalist (appearance mods) 2019
And because of that you stand a good chance of having an improvement in the sound quality with some aftermarket replacement speakers as the original oem ones may well be dried out and cracked. Please be sure to let us know what you used and what you think of the change after you get it done (if you do it)
