Yes.6speed lt1's from 92-95.Maybe 96 as an option??Every manual trans 96 I have seen is an LT4.
LT4 was an option on 97 trans am/z-28 also.Very rare but was available.
Any factory ordered 96 with a manual, got the LT4. If you find a 96 LT1 with a manual, then somebody changed something over at some point.
The f-bodies with the LT4 were done by SLP, if I remember correctly. Only a couple hundred made.
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'19-'20-'21-'22-'23
Originally Posted by dukeallen
Weren't there also 6 speed LT1s?
Only from '92-'95
As others have mentioned, all manual trans '96 cars were LT4
6-speed = LT4
Auto = LT1
No auto tranny LT4 cars, unless they've been converted.
And there are a few of them out there. One forum member here has one.
If you want to prove if a '96 is a factory LT4, look at the 8th character of the VIN.
P = LT1
5 = LT4
Under car
- Stock LT4 exhaust systems have a crossover tube on the exhaust. Look just ahead of the spare tire carrier. LT1 did not receive the crossover tube
Engine compartment
- remove engine oil fill cap
- LT4 should be stamped into the head (may need a flash light to see it)
