New Owner With 2 Problems
I just purchased a 1996 coupe and have a couple of issues that I'm trying to figure out.
When I shut off the car and get out the radio doesn't shut off. I haven't waited it out yet to see if it ever shuts off but after a good 5 minutes it was still on. Any idea what would cause this?
Also, my PKE system doesn't work. I have tried turning it on by holding the window button on the fob but nothing. The hatch button doesn't work either. When I shut off the car and open the door the PKE light doesn't come on in the information center. The alarm doesn't appear to work either. Any ideas?
Thanks in advance for any help!
Received 6,943 Likes
2015 C2 of Year Finalist
did you try a new battery in the key fob?
I would say 95 % chance the radio not shutting off is the door adjar switch, 20 bucks online 30 at dealer.
Are your interior lights coming on when the door is open if not it's the switch.
You should also get a security light on the dash when the door is opened.
Your radio will shut off after 15 min,even with a bad door switch.
Today I just switched my passenger side switch to my drivers side because itr wasn't working so good.
What do you mean by good? A couple tenths of a volt is enough to make them not work. Replace the battery, then go throught the programming procedure (in the owners manual). First check the fuses, 26, 40 and 42.
I agree the other problem sounds like a door switch. Do you get the "door ajar" light when you open it? Do the interior lights come on?
From the owners manual:
Turning the System Off
1. Take the ignition key out of the ignition.
2. Press DOOR on the transmitter until the door locks
cycle (about two seconds).
To turn the system back on, just repeat the steps.
Changing the Door Settings
1. Put the ignition key in the ignition, but don’t turn it
on.
cycle (about two seconds)....in my case.....it was more like 15-20 seconds.
1 problem solved - 1 to go
Good news on the radio problem - it is being caused by intermittent contact on the driver's side door switch. I'll have to get another one of those.
Now for the PKE. My fob battery voltage is 3.04 volts so it is good. I checked fuses 26, 40 and 42 - all good. I have tried to do the transmitter matching procedure in the owner's manual. Key on, push TRIP ODO twice, hold FUEL INFO on until PKE light comes on. Problem is that it never comes on. So, I'm thinking I have a vehicle problem but not a fob problem. Any more ideas?
....this sounds like the PKE has been turned 'OFF'. I know from personal experience on my 96, that if you press one of the FOB buttons unexpectedly, you can turn the system off.
on.
on.
...hang in there. The fact that the PKE light does not come on, could mean that the system is turned off. The last time this happened to me, (just a few weeks ago) I did everything you just did with no luck. I finally just let it go and the next morning the PKE was back on.
Sometimes disconnecting the battery for a few minutes acts like a reset.
The PKE control module is located behind central dash (fun) if you do have to replace.
There are others on the forum (RollaMO-LT4) who are far more knowledgeable than I.
Also try a forum search. Lots of discussion on PKE.
Location: The reason time exists is so everything doesn't happen at once
If you're going to replace the switch do a search for the procedure. If I recall, there's a backing plate in the door jamb that holds the screws for the switch. What you have to do is remove one of the screws then put a small awl or nail in the hole to keep the plate from dropping down into the door. Remove the second screw then the switch. Replace the switch and the first screw then remove the awl and replace the other screw.
