Need tires for a 85 C4
I am currently working on getting my 1985 C4 back on the road and I've run into a tire problem. I can't seem to find tires (255/50-16) for this year anywhere. I was wondering if anyone else has had this issue and could maybe recommend an alternative size tire for a 16" rim. I was hoping not to have to buy a larger set of rims.
Link to another thread about this same issue.
http://forums.corvetteforum.com/c4-g...ent-tires.html
If you don't want to move to a 17" rim, your options seem to be limited.
BFG's Are Available
Hello,
I have BFG's on my '87 Convertible. Nice tires for the stock wheels. They might be the last remaining manufacturer for the 16 inch stock wheel. You can find many choices though in the 245/50-16 size and even though it is slightly smaller in size, these tires should work. Otherwise, you will need to go to 17" wheels and there are multiple choices for tires.
Good luck.
Good luck.
I have the Falken tires on my 85 and I'm very happy with them, they were one of the few that made the correct size. They were cheap when I bought them 4 years ago ($50 each) and they are unidirectional like the original Goodyear tires that came from the factory. Do a search for ZIEX ZE-512 and you should find someone who has them in stock. I know Sears was selling them at one time too.
this may be the last hurrah -
http://www.tirerack.com/tires/tires....e&autoModClar=
get them while you can, or better yet, upgrade to 17 inchers...
So it looks like there is absolutely nothing in the BF Goodrich, and I'm striking out on the Falkens as well.
Can anyone tell me if it would be safe to move to a 245/50-16 and what impact it might have on the performance? It looks like my only option unless I move up to a 17".
Tirerack.com
Just checked, 255/50ZR-16 available and in stock for $130.50 each at Tirerack.com.
Ship them to your local Firestone dealer and they will install them for a mount and balance charge.
Big deal!
Big deal!
Just an FYI I noticed this is your first post and you replyed to a 5 year old post Jay
I saw the date too.
FWIW I just went through this on my '86 coupe. Current tire dealers list 225/50-16 on non-Z51 cars.
The RPO code was for the 255 tires along with the sticker on the door so I wouldn't go any narrower.
Jonathan.....
Jonathan.....
Tires
