Mo's Electric Corvette- Lot of Pictures
Old 03-19-2019, 12:34 PM
  #601
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
Recieved 36 Likes on 24 Posts
Thank you Polo, it is a lot of fun having the ability to "play" out side of the box so to speak.
I will post more as I get the last bits put together.
Mo
Mo_Bandy is offline
Old 03-19-2019, 12:36 PM
  #602
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
Originally Posted by colo63sw View Post
I am wondering if GM is calling Mo to get engineering insights to making the electric version of the C8 (I'll bet they do an electric C8 someday).
That would be cool! right now I'm pretty much the mad scientist of the neighborhood... LOL
Mo_Bandy is offline
Old 03-19-2019, 12:47 PM
  #603
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
So I was able to do a little more work this weekend...
Motors and controllers are in and placed. the battery chargers are to the right.
Controller cables are installed on the controllers.
High Voltage cables installed
I still am working out the motor mounts.
Obviously more to come!
MO
Mo_Bandy is offline
Old 03-23-2019, 08:00 AM
  #604
UV231 Project
CF Member
Recieved 2 Likes on 2 Posts
Default Mo's Electric Corvette - Lot of Pictures
Hey Wayne, Have you had time to dress up and secure the wiring? Have you taken it out yet?
UV231 Project is offline
Old 03-24-2019, 10:02 PM
  #605
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
funny you should ask.
Shortly after taking this picture, I was commissioning the motors and ran into a glitch.
I called and they had shipped the right serial numbers, shipped them in the right boxes, but accidentally shipped the wrong motors.
I had to completely tear tear everything down again to ship the motors back.
So, the correct motors have shipped and are supposed to be here the 26th. So I get to repeat the process. The upside is I have gone through this once so the next time should be much quicker. At least the controllers have been programmed so it should be a matter of just commissioning the motors, finishing the motor mounts.
I will post updates once the motors arrive “ again”...
thanks!
Mo
Mo_Bandy is offline
Old 04-10-2019, 12:55 AM
  #606
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
Sorry it has been so long since an update.
It has been crazy, the new motors are delivered and installed.
Long story, short, I was commissioning the motors and apparently blew both of my shorty power glides! So after swapping two power glides, I decided I was finished with them.
So I'm going direct drive with a 1.9:1 gear reduction box with my stock 3.07 rear end. Imagine running from 0-7800 rpm in first gear! 0- 105 mph without shifting! 6.14:1 overall gear ratio.
So I will be running essentially direct drive (below). So I will have the 3 buttons shown below to Select "Park" "Reverse " and "Forward". If say the reverse button accidently gets pushed while in drive, he controller will essentially cost the motors to 0 rpm and it defeats the throttle to keep from destroying the drive train and yet allow you to safely either pull over or just reselect the forward button.
Mine will not have the parking Pawl attached to it.
The button pictures below are inaccurate, Park will be red, reverse will be blue and forward will be green. They only have Red, Green, Blue and White Latching buttons.
The Torque Box weighs 35 pounds and is 12 inches long, so I will have to get a longer driveshaft. It looks like it may be up to an 8 weeks to get the torque box, I guess after waiting a year for the motors what's another 2 months :P
Attached are some pictures of the car thus far it is coming together.
Drive ( which is now green).
red is park, green is drive bluse is reverse, I have since changed the order so it is P,R,D as in all automatics
Still working on 3d printing the meter console.
The new motors in and siamesed together, running dual 14V 650 amp controllers.
The battery chargers the white box is mainly to clean up the managery of wire clutter.
drivers side view
Mo_Bandy is offline
Old 04-10-2019, 08:27 PM
  #607
Mr. Peabody
CF Senior Member
Support Corvetteforum!
Mr. Peabody's Avatar
Recieved 160 Likes on 139 Posts
Once again ......... really impressive. Thank you so much for sharing all of this. On your web site you might consider a darker font for the detail paragraphs; the light blue is too difficult for these old eyes to read.
Mr. Peabody is offline
Old 04-11-2019, 02:14 PM
  #608
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
Hey Mr. Peabody, Thank you for the suggestion, I actually went in and did some updates as well as darken the font. It was one of the canned pages.
Thanks again,
MO
Mo_Bandy is offline
Old 04-11-2019, 03:50 PM
  #609
colo63sw
CF Senior Member
colo63sw's Avatar
Recieved 53 Likes on 48 Posts
A shame you haft to run direct drive. Seems like that would eliminate some low end performance to accommodate a respectable top end.
Keep up the great work!
colo63sw is offline
Old 04-12-2019, 10:00 AM
  #610
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
Hey Colo63sw,
Thank you!
Actually no that isn’t the case. The motors make 340ft/lbs from 0-about 5000 RPM. Redline is 8000 rpm. The torque curve on electric motors is almost direct opposite of an internal combustion.
So it is essentially like running in low gear all the time. My Chevy Bolt is almost identical in that regard. With the powerglide my launches with first gear, I was pulling .76 G’s on launch with street tires.
With the powerglide I was running 1.80:1 the Torque Box is 1.90:1 which is of course a touch taller. I am sacrificing a bit at the top end, with the 2 speed powerglide top speed at 7500 rpm would be about 135 mph.
Actually i am fine with it, it tremendously simplifies things in regards to trans slipping and the trans pump ( because there was no torque converter).
So once the torque box arrives I will have more updates.
Thanks,
Mo
Mo_Bandy is offline
Quick Reply: Mo's Electric Corvette- Lot of Pictures
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
