I NEED HELP FAST!!!!!
Apr 24, 2002 | 09:24 PM
WILL 96 SPORT SEAT FIT IN A 1984 WITH STANDARD SEATS!!!!! I NEED TO KNOW FAST :confused:
Apr 24, 2002 | 10:19 PM
Re: I NEED HELP FAST!!!!! (400Vette)
I feel your pain. I'd like to help you out but I really don't know...all I can say is that there was a hell of a lot of changes between 84 and 96...if the seats will fit you will most likely have to do some heavy modifications.
Apr 24, 2002 | 10:48 PM
the seats will fit, physically... or should... however, the electronics changed and the plugs won't line up.
so... you should be able to remove the rails and put the 96 seat onto the 84 rail...
Apr 25, 2002 | 08:17 PM
So you are sayin my power seats wont work !!???? are the wires the same color//....
Apr 26, 2002 | 06:20 PM
the connectors changed in 88 or so.
Apr 26, 2002 | 06:26 PM
Re: I NEED HELP FAST!!!!! (bogus)
Well are the wires the same color (84 -96 ) ...What i m askin is can you take the plug off the 84 and wire it onto the 96 ..............I really want to use these seats ...without a bunch of BS.......Got to much money in them to not.. :confused:
Apr 27, 2002 | 12:32 AM
I would simply remove the seats from the rails and transfer the old rails to the new seats.
Apr 27, 2002 | 10:01 PM
:cheers: thanks guys !!!!!!!! :cheers:
