Removed my shift indicator console(automatic) only 1 bulb but 2 sockets??
I've replaced almost all my interior lights with blue leds so I figured I would also do the shift indicator. I had known for some time that there was only one bulb so I bought two new sockets and two blue spade type led bulbs & wired them in. I really like the look with the blue lights, white bulbs may be too bright with two of them.
The console plate I bought does not come with the bulbs for the indicator light. Does anyone have a part number for the bulb sockets?
I would be OK with a NAPA part number, it does not need to be a GM OEM part.
ANYBODY?
http://www.acdelcotechconnect.com/pa...tails-catalog/
bullguts (09-27-2016)
Funny thing is that when I bought my C4 auto ,( 5 years ago now ) the part that shows PRND21 was blank so I bought a new one but it did not sit properly in place in the consul , so had to get it to sit right by moving into correct position and fastening with screws at each end through the plate and put the bulb at the 1 end , It got that hot that it burnt out the window up & down switch . Lesson learned and put the bulb at the P end . No big deal really , but when it happened it was raining hard and the window was down . Cheers
https://www.corvetteforum.com/forums...post1585982944
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
The general was saving pennies maybe?
Anyways I installed the second bulb and the illumination was way too bright.
Removed it...
Removed it...
bullguts (09-29-2016)
I doubt there is a separate bulb socket available. Usually they were part of a harness and not sold separately. That said, you might want to look at this:
Tony Paccione
Jersey Shore Area
bullguts (10-04-2016)
