84 & 85 Chassis ?
build sheet in frame.
At the factory someone stuffed a build sheet into the frame that may still be there.
Sit on the passenger front wheel and look down at the frame for a D stamped hole. It is just big enough for your little finger. If you feel a piece of paper there you can tweezer it out.
None that you can feel. Might make a difference on the dyno. With only 165 rwhp, anything will help. The intake is the first of many bottlenecks on that engine.
