C4 AFTERMARKET: What support do you want?
#42
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
-Corvette Central sells a Pioneer replacement for the Bose. This is to be used with the Bose speakers.
How about a customized stereo kit to order?
The customer would have the option of radio (USB, AUX, iPod etc), speakers, boom box etc.
-A replacement for the spare tire. The newest spare tire would be 16 years old.
-Fuel Rails Covers' C4 emblems.
-BF Goodrich KWD 315/35ZR17 tires
#44
Former Vendor
I missed out on an 84 for $450. I was going to use it for pieces to design new parts. Thanks for the link to the C4 for $2500, but that is over the limit for what I will do with it. I need a good deal under $1000 from 84-89 within 5 hours of Jacksonville FL. I have a great deal of money going out for design of new parts, so I set a low budget for the spare parts car.
We don't sell tires, so I can't be a lot of help with the 315 tires. I am planning to go up to 345 on mine anyways.
We are getting quite a bit of support for our X-Longitudinal-Brace thread. I plan on starting that project this weekend.
http://forums.corvetteforum.com/c4-t...nterested.html
I need a donar car for many of the other projects. If you are close to Jacksonville FL and want to be part of new products, send me an email.
We will look into the gauge pillar pods probably next week. I think that project will be simple, but how many people want this type of product. Send us an email, because it is the only way we can determine support level for products.
Carbon fiber dashes can be done quickly, but I need a donor car or borrowed parts.
Thanks,
Brandon
rppcorvette2@gmail.com
www.riceperformanceproducts.com
Thanks,
Brandon
#45
Former Vendor
I started welding the brackets for my new X-Brace design. It was easier than I expected since it has been so long since I did any welding. I constructed the majority of the front two mounting plates and I cut most of the pieces to make the rear mounting plates. I could use the original holes in the front and back, but I don't think that will take full advantage of the system. I am going to make ledges on all mounting plates that can be drilled and bolted to the frame lips. I think that will add maximum structure to the car. There is not a lot of room under the floorpans so I think I am going to use rectangular tubing. I have seen the designs that use flat plate, but I think I can do better than that.
I am still looking for an 84-89 cheap or anyone close to Jacksonville, FL that is interest in assisting with new products.
Thanks,
Brandon
Thanks,
Brandon
#46
I'd be all for a lip spoiler but not near as big as the one you are working on. Something with a base that would be big enough to cover the top of the rear fascia and not much more than an 1 to 1 1/2 inches tall.
#48
Former Vendor
For the speaker and stereo question, I usually just go through crutchfield for my stuff. What in particular do you need that is not available. I don't want to compete with large scale electronics companies (like fighting mike tyson).
Manual steering rack: Why? Would better aftermarket parts make the power unit better.
Now I'm beat. Welding and grinding all day on the X-brace prototype.
Thanks,
Brandon
#49
New seatbelts would be nice. I don't think anyone make those for our cars.
#50
I have an idea that would probably be easier for you... and very functional!
I would pick up a set of reverse lights! I think the earlier models are thinner than the later ones... but both of them provide plenty of space I would think to improve on the lackluster lighting!
#51
Look at a C3 antenna. My '71 had a solid rod with a nut at the bottom that held it in place. I used to loosen the nut and pull out the rod to put my car cover on.
The only disadvantage to this option is that the rod is 30" long (tuned to the middle of the FM band) -- not exactly "stubby".
#52
#53
1. The new ZR1 lip.
goes across the entire rear of the car but doesnt stick up extremely far but still looks functional
2. The exagerated lip that came on the callaway supernatural models with the two joined double tail lights. Looks just like the slight lip that came on all rear bumpers 91-96 just slightly higher
3. Something like the lip that is on the rear bumber ACI sells that is called something like a C5 conversion bumber but it looks nothing like the actual shape of the huge butt C5 bumper, it just has the oval tail lights instead of the square tail lights along with a built in lip that looks very similar to number 1.
#54
Manual steering rack... I have to replace my power steering pump now and since I have the basic alt, power steering pump, tension rod set-up I thought I could upgrade the bracket set-up.Flamingriver.com has a nice adj. one. That and a new alt. bracket now we're talking money(for me anyway).So a manual rack might not cost me much more. That and the spartan approach, If it ain't there it can't break.
#55
Former Vendor
A plug and play set of HIDs to replace the stock reverse lights with now yellowed and grundgy lenses at a decent price would sell pretty quick I imagine. I know I would be in line. SHouldnt be to expensive to fab up either after you do the initial homework and research on it.
Thanks,
Brandon
#56
I would like to see quality replacement interior panels that dont cost an arm and a leg and dont have the feel consistent with chinese sweatshop products.
On that note, a double din conversion kit, to include a trim piece that doenst cost so much for a piece of plastic.
#57
In fact, I've already replaced my backup lights with bright white LED bulbs.
Cooler, brighter, and way less current draw.
I did replace my fog lights with 5000k HID's, but all of my other exterior and interior lighting has been replaced with LED's.
#58
Double din conversion for the digital dash? Yes please!
#59
