Battery Drain with Battery Tender attached
Old 10-29-2012, 04:06 PM
jcevans
jcevans's Avatar
Default Battery Drain with Battery Tender attached
Recently replaced the battery in my 89 coupe about 4 months ago. Attached a battery tender as always and all was well for a time. Recently the battery tender flashed green which indicates 80% charge and this lasted for a couple of months. When I drove the car then hooked up the tender afterwards it would show a constant green light on the battery tender for about 4 days or so, then begin flashing green, red light constant. Last night I noticed the red light on and the battery was dead. I realise I have a drain of some sort, but I am stumped why the battery tender wouldn't at least hold to 80% like it had been. Any ideas?
Old 10-29-2012, 06:20 PM
Muffin
Support Corvetteforum!
Muffin's Avatar
My new-to-me ZR1 is doing something similar.
Old 10-29-2012, 07:36 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
When all was well, if the tender was not hooked up at night, was the battery dead by daytime?
Old 10-29-2012, 07:48 PM
WVZR-1
WVZR-1's Avatar
Received 2,258 Likes on 2,021 Posts
Both of you need to check first for "parasitic" draw on the vehicle. I'd suggest a "google search" for it and read some tutorials. It's very straight forward and you'll need a DMM to accomplish it.
It need NOT be an expensive purchase and you'll eventually need one if you intend on DIY repairs and diagnostics. I wouldn't "cheap-out" on one but it doesn't need to be a major purchase either. Less than 30 minutes and you'll know if you've a problem or NOT. You won't know where but you'll know if there's a problem.
OP - I believe some/most have a 72 hour timer of sorts and if there were a problem with a "sulfated" battery or other issues it might actually "shut down". Read the explanation of lamps on your specific model. Maybe check entire charging system.
Old 10-30-2012, 09:09 AM
jcevans
jcevans's Avatar
The battery tender was hooked up continually. I haven't driven the car for 30-45 days.
Old 10-30-2012, 09:14 AM
jcevans
jcevans's Avatar
What is a DMM? I have the factory service manuals.
Old 10-30-2012, 10:02 AM
c4cruiser
c4cruiser's Avatar
Digital Multi Meter. You need one that can display current draw in at least tenths of amps (look for a "mA' selection on the DMM). Sears would be a good place to get one' check out the Craftsman Autoranging Multimeter #82141, about $23
Most tenders don't provide much more than 1 to 1.4 amps. It's possible that there is a current draw in the car that equal to or even greater than what the tender can supply. You could also have a bad battery. Have it load tested to see if it needs replacement. Do this first before looking for parasitic current draws.
Old 10-30-2012, 10:12 AM
WVZR-1
WVZR-1's Avatar
When/if you buy the Sears 82141 make sure you buy a couple extra fuses. I believe there are 2 different ones. I don't have an 82141 but I know a fellow that blew a few fuses getting a grip on his draws. The battery load test is first.
To Battery Drain with Battery Tender attached
Quick Reply: Battery Drain with Battery Tender attached
