Another PKE question
Old Dec 8, 2013 | 02:21 PM
KevinMillerSr's Avatar
KevinMillerSr
Default Another PKE question
What does it mean when the PKE info center light is on with no key in the ignition??
Old Dec 9, 2013 | 01:47 PM
markKlein's Avatar
markKlein
My guess is it means the receiver is starting to malfunction. Does everything still work it should?
Old Dec 9, 2013 | 02:28 PM
KevinMillerSr
When I can program it, ti does work the way it should...
Old Dec 9, 2013 | 05:59 PM
markKlein's Avatar
markKlein
Does that mean you can't program it now? Is everything working now, or?
Old Dec 9, 2013 | 06:07 PM
KevinMillerSr
I can't program it right now
Old Dec 10, 2013 | 09:55 AM
markKlein's Avatar
markKlein
So it was working, but stopped. And you can't reprogram it (you shouldn't have to reprogram it unless you get a new fob). Again, it sounds like the receiver is going bad to me. If you have an FSM you should be able to go step by step to confirm, bit I'm afraid you need a new one. There are plenty of posts on removing/replacing it if you decide to do that.
To Another PKE question
