Just for the hell of it....
Old 07-31-2016, 01:36 PM
  #41
PLRX
Semper Fidelis 1988-2011
PLRX's Avatar
Recieved 392 Likes on 270 Posts
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
How come you didnt use coilovers?
PLRX is offline
Old 08-01-2016, 10:49 AM
  #42
FostersPerformance
CF Senior Member
FostersPerformance's Avatar
Recieved 12 Likes on 10 Posts
Have VBP sport spring rear and exteme front i bought years ago. Also full VBP goodies in the rear, and all new Bilsteins around. All poly bushings front and rear, as well as all new ball joints etc....Figured id see how she goes. If i go coilovers i could always do that on a saturday....
FostersPerformance is offline
Old 08-01-2016, 01:50 PM
  #43
cadmaniac
CF Senior Member
cadmaniac's Avatar
Recieved 24 Likes on 24 Posts
Without the air pump delete bracket/pulley, I'd check and make sure the serpentine belt doesn't "flap" too much, especially if used for racing applications. That looks like a long way across the engine with no pulley, especially when you torque the engine.
Very nice build!
cadmaniac is offline
Old 08-02-2016, 02:57 PM
  #44
FostersPerformance
CF Senior Member
Very nice build!
The only part left from original engine is the p/s bracket. The idle pulley is adjustable, and i made it from a boat engine setup (boat tech, 22 years). These engines turn 5500 rpm all day long, 100% power, and in fact go across the top of engine like mine another 6 inches. Never had a belt issue. If it looks weird in photo its only mocked up, the belt isnt tight.
Thanks for the compliment!
Old 09-30-2017, 09:02 AM
  #45
FostersPerformance
CF Senior Member
Some updates
Old 09-30-2017, 09:03 AM
  #46
FostersPerformance
CF Senior Member
Old 09-30-2017, 09:04 AM
  #47
FostersPerformance
CF Senior Member
1993C4LT1 (10-02-2017)
  #48
FostersPerformance
CF Senior Member
Old 09-30-2017, 09:05 AM
  #49
FostersPerformance
CF Senior Member
Old 09-30-2017, 09:06 AM
  #50
FostersPerformance
CF Senior Member
Old 09-30-2017, 09:07 AM
  #51
FostersPerformance
CF Senior Member
Old 09-30-2017, 09:08 AM
  #52
FostersPerformance
CF Senior Member
bobandc (09-30-2017)
Old 09-30-2017, 10:48 AM
  #53
1993C4LT1
CF Senior Member
1993C4LT1's Avatar
Recieved 366 Likes on 323 Posts
Sick! What do you mean by reverse pattern manual valve body?
1993C4LT1 is offline
Old 09-30-2017, 11:01 AM
  #54
FASTAZU
CF Senior Member
FASTAZU's Avatar
Recieved 285 Likes on 260 Posts
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
looking great
FASTAZU is offline
Old 09-30-2017, 12:24 PM
  #55
BrandensBeast
CF Senior Member
BrandensBeast's Avatar
Recieved 142 Likes on 135 Posts
Nice!!!
BrandensBeast is offline
Old 10-01-2017, 09:41 AM
  #56
FostersPerformance
CF Senior Member
Reverse pattern manual valve body is just that. Instead of PRN4321, its now PRN1234. Works perfectly with a ratchet shifter (i have the BandM megashifter) Otherwise when you shift from park to drive, it would now be 4th, and the car would stall. There are no upshifts, or downshifts - you control it. Other advantages too, like its easier to pull the shifter back to upshift, and slowing down its easier to push forward to downshift. Had a few cars this way - i think its the only way to go.
Old 10-02-2017, 10:07 PM
  #57
1993C4LT1
CF Senior Member
1993C4LT1's Avatar
Dude that is Badass! Sounds fun
Old 12-27-2017, 09:45 AM
  #58
FostersPerformance
CF Senior Member
Engine was born 11/20/17. Pretty sure i had a tear run down my cheek lol....Sounds good, no issues, dropping it in the car maybe this sat......
Old 12-27-2017, 09:49 AM
  #59
FostersPerformance
CF Senior Member
Have to have hedders coated while i drop engine in. Trying to find a Y-pipe in the meantime. This was the engine mocked up to run up and check over. Had water to it, ran for about 10 mins or so - no issues. Im a happy camper.
Old 12-27-2017, 10:23 AM
  #60
85 Stalker
CF Senior Member
85 Stalker's Avatar
Recieved 22 Likes on 18 Posts
How are you going to trim around the shifter? Using the original cover trimmed to fit?
Everything is looking great!
85 Stalker is offline
Quick Reply: Just for the hell of it....
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
