A little help
you have to remove the hush panel under the steering wheel. It is buried up around the steering wheel on the left side of the wheel.
Believe it is this...it has been awhile since I replaced the one on my friends 94...
https://www.rockauto.com/catalog/mor...nid=503&jpid=0
Left of the column and actually I believe maybe just left of clutch pedal. Left of column I believe goes relay, relay and extreme left the flasher.
You mentioned TURN ...
It is NOT that. The GM reference 10041073 should work. An original might be yellow. Your link might be a horn relay. I never - never rely on or buy from RA.
