Mark relationship of driveshaft to pinion
I seem to be making every possible mistake on my first ever rebuild experience. Today it's replacing the drive line ( I always thought it was called a drive shaft). As I was putting the 'drive line' on I discovered it would not fit with C-Beam installed. With incredible disbelief I rushed to the service manual and sho-nuff. (expletive) It was a bitch getting those C-Beam bolts lined up and now I have to take at least 3 off? grrr
But what I noticed in the manual is it says to mark relationship of drive line to pinion. WTF?? I'm piecing this thing together after it was disassembled years ago and there aren't any markings that I see. How important is this and what can I do to mitigate?
What is the project?
Pro Mechanic
Not important.
The drive shaft (I call it a drive shaft, b/c it's a shaft). is balanced by itself...not as an assembly with the pinion, so it doesn't matter which way it goes back together.
You have no choice and you will NOT have any issues. Did you replace or were any u-joints replaced while the drive-shaft was out of the car? It is customary to index the relationship of the shaft to the pinion when you remove but it's certainly seldom an issue. Relax - it will likely get worse. Enjoy the moments and the project.
here's a couple shots of the area I'm talking about -
