What's your experience with the C4 hood emergency tool?
Old 08-25-2015, 06:56 PM
johngammel
Support Corvetteforum!
johngammel's Avatar
2017 C4 of the Year Finalist
Default What's your experience with the C4 hood emergency tool?
I bought this C4 emergency hood opening tool for my '88 Anniversary. I appears that the only way this would actually work would result in damaging/ruining the seal and scratching the hood. The vendor hasn't been able to provide an actual demonstration video of the tool in use or any technical assistance.
Who has actually used this tool and what was your experience?
Old 08-25-2015, 07:23 PM
92ragtop
92ragtop's Avatar
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Send it back, and just install some emergency release cables. Tons of threads on that topic.
Old 08-25-2015, 07:38 PM
waddiejohn
waddiejohn's Avatar
Install the emergency release cables NOW. I sure wish I had. I haven't found tons of threads on this subject but maybe I'm not searching right. I'm pretty new at this.
Old 08-25-2015, 08:13 PM
MITCH
MITCH's Avatar
I am surprised about all the post about this problem and tools and cables.
My hood got stuck and I took the wheel off and took off the upper plastic wheel well and reached in and open the hood by pressing on the latch end where the cable goes and it popped right open.
Hope this helps
Mitch
Old 08-25-2015, 08:55 PM
corvetteronw
corvetteronw's Avatar
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Here's mine. Easy to do and inexpensive:
Old 08-25-2015, 08:59 PM
antfarmer2
antfarmer2's Avatar
I used stainless steel fish leaders
Old 08-25-2015, 09:01 PM
corvetteronw
Cruise-In VIII
Found this:
Old 08-25-2015, 11:02 PM
chadk
chadk's Avatar
Hope this helps
Mitch
I really dislike the look of the "what if" cables dangling under the hood. I like your idea much better. Can anyone vouch this technique works?
How about preventative maintenance and inspect/replace the cables? Is there a common area where the cable(s) break?
Old 08-25-2015, 11:17 PM
antfarmer2
antfarmer2's Avatar
The fish leader tuck and hide
Old 08-25-2015, 11:19 PM
ghoastrider1
ghoastrider1's Avatar
Originally Posted by corvetteronw
I have the tool and have had to use it a couple of times. This is a good video posted by Corvetteronw. If you take your time and DONT get pissed off ( like I did), you wont hurt the seal. Best to go past the the lock and then bring the tool back towards you. On the pass. side, flip the tool to the left to release the lock, same on the drivers side but to the right. I had to use it three times. Second was cause I tripped and caught myself on the hood..snap/clunk, locked. Cussing, I reopened it. Third time the wife leaned on the hood..clunk/snap locked. I then installed the emerg cables AND replacement cables. It works and is simple to use ...the second time you need it. If you lived closer, I would help.
Old 08-26-2015, 07:57 AM
johngammel
johngammel's Avatar
The car in the video doesn't have "fender" seals like mine does (see pic). I will give it another go and maybe have yet another person try it out. I do have pulls on my '61 but they are fishing line leaders and just blend in because they are short and just go straight back. The pulls as shown cut through the long seal and I likely loose a lot of NCRS points if I do that.
I give this a little more time and maybe have a different person try it as well.
Old 08-27-2015, 11:36 AM
VikingTrad3r
Oil Producer
VikingTrad3r's Avatar
Received 2,261 Likes on 1,446 Posts
once u get it open, install the emerg cables and be done with it.
Old 08-27-2015, 12:27 PM
Goldcylon
Goldcylon's Avatar
The tool is time consuming unless you have a lot of practice. My argument is that if you cant get it open in an emergency its worthless. The cables that everybody mentioned already and that I have solve the problem in both emergency and non emergency events when you need access to the hood and the factory pull brakes. Just my thoughts
Old 08-27-2015, 01:38 PM
MavsAK
MavsAK's Avatar
The hood release tool does indeed work. It will probably scratch the underside of your hood, at some point.
I needed it after mine snapped the plastic retainers under hood. Glad I bought it, I had the hood open in less than five minutes.
Definitely get some hood emergency release cables though.
Old 08-27-2015, 02:52 PM
redrose
redrose's Avatar
Originally Posted by MavsAK
The hood release tool does indeed work. .
'best' to get a fellow c4 to open his hood, 'practice' with his hood up so ya can see/learn.
Old 08-27-2015, 04:18 PM
PAINTER MAN
PAINTER MAN's Avatar
I opened the hood on a friends 86 using this method.
To What's your experience with the C4 hood emergency tool?
Quick Reply: What's your experience with the C4 hood emergency tool?
