1995 doors unlock when i shut the door
Weird thing going on. When I close the drivers door both door will unlock. I don't have a FOB for the PKE. Is this functionality something programmed into the car or do I have an electrical gremlin? All the lock/unlock buttons work properly. I think this is with the key in the ignition only because I can lock my doors and close them and they stay locked when I have the keys on me.
would you rather lock your keys in your car?
chadk (10-24-2015)
No. Of course not. If by design then this is great idea. I have never seen this done before and wondered if this was part of the PKE system. Most cars lock the doors when the shifter is moved to drive. I never seen one unlock the door.
chadk (10-24-2015)
Thanks for you great help 8Vette7. The car tyre sensors work all 4 as I drove it last night for 80 miles or so. The chap had replaced the rear sensors as I met him last night. He also said that he managed to connect the fob and the horn beeped. It's not working now and think it must be the fob. I wonder if there is a test to see if it emits a signal? On another note I have a slight oil leak and it hits the exhaust we cleaned the area but couldn't see where it's coming from. It was quite wet under there. It looks dry 6" above pan all round the engine apart from maybe the very front of the engine.
Thanks, I changed it and so did the previous keeper who imported it as he obviously had this problem also. I do believe him that he did pair it recently but maybe it's completely dead now. I don't suppose the car battery going dead due to a light left on has anything to do with it as it won't pair. I'll try one more time now and re read codes today to see if there are any repeat offenders!
