Suspension advise needed. (Ecklers rebuild kit?)
I am considering getting the front suspension rebuild kit from Ecklers that includes: Upper and lower ball-joints, tie-rod ends, and urethane bushings. All for about $270.00. I am also going to finish up with urethane bushings for the rear.
Can anyone advise me if there is a better route to go. I have priced ball joints locally and the prices vary wildly. I have seen as much as $115.00 ea for ball joints and as little as $49.95 ea.
I want to spend as little money as possible but, I don't want to buy cheap parts and regret it later.
Any help or advise is much appreciated.
BTW. My car has a little over 100k and I get some vibration from the front end. Also, when I first start the car and back out of the garage, when I put it in reverse with the brake on I get a pop/snap from the front suspension. I am assuming that it is the front ball joints. The control arm bushings are full of cracks around the outside edge that shows.
I am planning on ordering the parts later this afternoon or tomorrow. I want to do the work this week-end.
Thanks,
Mike. :cheers:
Thanks,
Mike. :cheers:
Re: Suspension advise needed. (Midnite 88)
Try this place
http://www.rockauto.com/
I bought most all my suspension parts from them. All of it Moog, all at good prices.
For Poly, check summitracing for energy suspension kits.
I got both front and rear kits at www.p-s-t.com The price can't be beat. Order more lube for the poly bushings at the same time because they don't give you enough.
Re: Suspension advise needed. (Bluevette85)
Thanks to all for the advise. I ordered my parts from P-S-T. I couldn't find a better price and the CSR thar I talked to was very knowledgable.
Mike.
Mike.
