No A/C or heat
Location: The reason time exists is so everything doesn't happen at once
No A/C or heat
My 93 coupe's air conditioning system no longer blows cold air. The system is charged and there are no apparent leaks. Also, there is no heat either. Again, no leaks. The fan operates but only blows air, neither hot or cold. The car has RPO C68 Electronic Air Conditioning Control.
Any suggestions?
thanks
Any suggestions?
thanks
Any suggestions?
thanks
Any suggestions?
thanks
Any suggestions?
thanks
Any suggestions?
thanks
Yes watch this video which is the best I have seen to date which takes you into the C68 diagnostic code procedure and has a portion that shows in the Factory Service Manual (FSM) what the codes mean. I suggest this would be a good place to start. GC
https://www.youtube.com/watch?v=lWIrT8tN-a8
Enderlin (06-20-2016)
Just did the check as in the video; got a code 09, Low Refrigerant Detected. Still doesn't explain why there's no heat but since I don't use the car too much in the winter that's not a real concern. Now all I have to do is hope to find an A/C shop that can refill an R-12 system.
It might be might be a plugged heater core. I would flush it and look for leaks or bypass if not needed.
For earlier cars, see this:
https://www.corvetteforum.com/forums...stic-mode.html
