who repairs 92 speedo cluster
Have you had a VSS error code previously that set a MIL code? Have you scanned for codes?
Do all of the other functions of the cluster LCD function? Does the GAUGES function from the DIC work as it should?
Just so you know thougj, module masters does them. On website it says they are on hold, I called and talked to them, they will do it if you talk to them. Their tech is just busy is all.
Bates is used a lot in here might be off on the spelling.
Just a FYI regarding the speedo display... if you are losing the LCD display and it is an intermittent comes and goes... could be a bad contact BEHIND the cluster with the mating harness the cluster plugs into.
That scenario happened to me...
I haven't checked any codes. I actually had another speedo cluster installed and it is doing the same thing. On for 10 minutes or so then off for 5 minutes or so then back off then back on. All gauges stay working.
you mean Batee?
http://batee.com/
Sounds like possibly the light sensor for brightening/dimming the cluster is going out.
http://batee.com/
