Targa top doesn't fit
Does it line up in the back?
Also where is the Weather stripping from (it will make a difference)
I doubt it, but you never know. I made sure to test fit before I installed it. Hope I didn't install it wrong.
Ok..
you did not replace Targa W/S correct?
did you get the latex W/S from Willcox?
How soft is the top corners of the A pillar?
Can you post some pictures of the W/S stripping along the A and B pillars, Without the top on?
No, I didn't replace the targa W/S.
It is soft, I'd say about a 6/10. It definitely doesn't feel hard.
I'm not sure if these I bought are latex. It doesn't mention it. But here are the links I bought from.https://willcoxcorvette.com/corvette...e-window-84-96
https://willcoxcorvette.com/corvette...d-pillar-84-96
Pics without targa on:
ok.. make sure the W/S is fully seated in the W/S Rails. I assume you cleaned everything. did you use W/S Adhesive? I did not on my car.. no leaks for 9 years. you may have to apply a bit a pressure in the back. both holes should still line up. see if you can bolt them in. then work at the front. the W/S is new and needs to compress.
Do the corners of the A pillar seem hard(ish) or soft?
How dot he windows seal? usually when doing W/S you are readjusting windows too
A pillar corners are soft. I'd say about 6/10 on a soft level. I'll double check the rails. I did use 3m W/S glue. Wish I knew we didn't have to
With roof on, windows up, it looks like they seal nicely. The driver's side has always needed a window adjustment. Not a lot though. Yes, I took a long time making the tracks clean.
okay, you might be fine.. work on getting the top bolted.. back bolts first, get one started then the other, working back and forth some what evenly
same for the front..
Let us know how it goes..
1993C4LT1 (10-07-2016)
