LTCC 1992 Corvette Install
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Well guys, the WPS opti I got for 100 bucks just croaked after roughly 4k miles. lost low and high res pulse. Just replaced the unit with a petris enterprise unit. The conversion is still running very well!
Connor, could you open your LTCC box, and see how it looks inside? Curious because we have been running the system for exactly the same time. Maybe post a pic or two? I'm having a no spark, but do get injector pulse. I believe my LTCC box is dead.
Connor Coughlin
1993C4LT1 (04-03-2018)
It has me stumped to say the least. It's like the car fires up whenever it wants to.
Here is how my box looks on the inside. And I put 3 microfiber towels on top of the brain box every wash.
Thanks a lot man, no rush! Sounds true on what you say about the injector pulse. But I am not sure either.
Pro Mechanic
#34
2017 C4 of Year
This got my ATTENTION. I will check my box, I remember seeing a rubber seal there, but now I'm not totally confident.
#36
Brandon,
Were you able to get a hold of Bob Bailey? All your grounds check out good? I find it hard to believe the brain box would crap out in that location. I never put anything over my LTCC box when I wash, the seal around the lid and the o-rings around the screws are more than sufficient. You trace all the wiring make sure everything looks good?
Also, did you build your own spark plug wires or order them I can't remember?
#37
1993C4LT1 (04-06-2018)
