Why does a 1993 have a faster 0-60 time than both the 1994 and 1995?
You are not specific as to the engine in question, but the same answer could be used for both the LT1 or the LT5. You are comparing tests in potentially different conditions with different drivers. Line the three up with the same driver on the same day on one track and you would likely find identical results for all three
Pro Mechanic
The cars got heavier withy each year's changes. That is the only diff, and it's a slight one. I'd say bb62 is right; conditions and driver have a bigger impact on the variations that you're asking about.
Pro Mechanic
All the stick shift, LT1 cars do, and all the stick shift, LT5 cars do.
Auto LT1's could have had a couple different rear ratios.
The 94-95 cars had sequential FI, and greater engine management, and slightly more weight. BB62 pretty much nailed it though, unless you side by side them there is no way of telling. For years, European manufacturers would bring race prepared cars and professional drivers on favorable tracks to "test" their cars, and usually came up with fantastic numbers in the car magazines. In the 90's Ford did it with their Mustang Cobras and ended up getting sued by the Cobra owners who were getting creamed by LT1 Camaros with less horsepower.
ive got to assume its either:
1. increased weight with additional features (ex. passenger side airbag was added in 94
2. less options on the 93 (ex. no power seat, bose, etc) vs a fully loaded 94/95 car (and-or driver / fuel loading)
3. different weather conditions.
Just sayin.
It does beg the question on if the batch fire speed density early LT1's 300 hp was fatter across the rpm range than the 94-96 LT1 with the mass air flow sequential injection. Seem like GM was always rating the torque a little different each year.
Pro Mechanic
The tq rating changed (for the better) as time went on due to cam changes -mostly. '92 had the lowest peak tq rating.
